A counter-weight is feasible. In use by variety of machine tools; especially in sliding heads of jigbores and drills like the Cleereman, operating in the hollow columns. They use a sprocket and 1 or 2 rows of roller chain connected at the upper end of head, weight of course at other end.
None are neutral or weight cancelling, just reduction so the head doesn't float upward.
In the case of a leadscrew raising a machine element, the same principle would apply. Less effort is nice; still want a leadscrew to bear load for backlash compensation. Otherwise the dial or readout will be useless. Lazy google search indicates a 9 x 30 knee & table at 400-460 lbs, 10 x 54's at 500. Seems reasonable target, considering weight of vises, rotabs, indexers etc. Designed load on 9 x 30 is 750lb workpiece.
A pair of flanged bearings outside the column would support a shaft and sprockets through it. They have self aligning feature built in. Place high enough for full upward travel.
A pair of standoffs on the knee would anchor the roller chain. That would ensure upper end of knee contacts column, leverage presses lower end into contact. Place high enough so a pair of weights operate without contacting machine base or floor.
