Results 1 to 6 of 6
Thread: Milling and CNC Lock Down Vise
    jjr2001's Tools
    Milling and CNC Lock Down Vise Plans Included
    This is a precision low profile Milling and CNC vise. It is 2.37 inches high and has a capacity
    of 4 inches wide and 5 inches long. It is a lock down vise and can be operated with a single
    3/16 inch allen wrench. Lead screw is a standard 1/2"-13 tpi screw with the end modified
    to fit the moveable jaw assembly. While it does require milling for the large base I will also
    have a set of plans for one that has the base made from bar stock without milling.
    My Kurt style lock down vise is over 3.6" tall so I gain 1.2" of head room with this model.
    It will fit equally on my CNC machine, Sherline Mill, or Mini Mill. It also gains 1" in length
    capacity over my Kurt Style vise.
    Operation does require use of one allen wrench to both pull the jaws tight and lock
    them down to the base. Once setup for a dimension it can be reset and adjusted for
    parts that are within 1.5" wide with only three allen adjustments since the lead screw
    provides 1.5" of travel. Any size part that can fit between the jaws can be adjusted
    using 5 of the 1/4" allen cap screws on the jaws and lead screw. It is not as bad as it
    sounds, we are talking about 1/8 th of a turn on the lock down screws and maybe 1/4
    turn of the lead screw to secure any part. The lead screw does have a knurled knob
    for fast adjustments.
    Version 2 is a bar stock version for the base that does not require milling.
    There is also the optional custom work stop shown in another post in this thread.
ID:	48331   Click image for larger version.
ID:	48332   Click image for larger version.
ID:	48333   Click image for larger version.
ID:	48334   Click image for larger version.
ID:	48336   Click image for larger version.
ID:	48337   Click image for larger version.
ID:	48338   Click image for larger version.
ID:	48339   Click image for larger version.
    Attached Files Attached Files
    Back to the shop.
  2. The Following 4 Users Say Thank You to jjr2001 For This Useful Post:
    emu roo (Nov 20, 2024), Jon (Nov 19, 2024), Paul Jones (Jan 19, 2025), Saltfever (Nov 23, 2024)
