Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Milling and CNC Machine Hold Down Clamps
    Supporting Member scrdmgl's Avatar
    Oct 2013
    Toronto, Ontario, Canada
    scrdmgl's Tools
    Hi JR: I'm yet to build my own version of these clamps. As they say, "Ambition killed the cat", in that case I'm bound to perish before my time is up.
    The idea being, for one set of clamps to serve two purposes. Such as thin pieces or those that need to be machined in its entirety, top holding clamps would be an impediment to the job when its size, exceeds the capacity of a regular mill vise. For those cases, I feel that a solid and square parallel, bolted across the width of the mill's table on one end should do the trick, with an edge contact clamp, pushing the opposite side. I can see now that a tilted ramp would be necessary as an addition to a pivoting locking bolt. That way the front of the clamp would be moving forward and also exerting downward pressure of the work piece when tightening the locking bolt. Increasing the height of the clamp's body to accommodate the ramp, is not an issue since it would be in an open area. Your addition of micro roller bearings to the design, is an excellent way to facilitate sliding of the unit.
    I'll be working on a design along those lines. Let me suggest to you, that the value of exchange of ideas can not be overestimated. You inspire me, I inspire somebody else and on, and on, and on.
    Cheers
    Jorge
  2. The Following User Says Thank You to scrdmgl For This Useful Post:
    jjr2001 (Jan 31, 2018)
  3. #12
    jjr2001's Tools
    Awesome Jorge, please post your design when it is on paper or "in the metal".
    Like the old saying goes:
    Always better to have too many clamps than to not have enough clamps.
    Cheers, JR
  4. #13
    Syko Triker's Avatar
    Jul 2015
    Somerset UK
    "Great minds think alike" as the saying goes, just made 6 60mm clamps and 6 40mm clamps of the same design.
    My next job is to make a new pallet, and then a filing machine.
  5. The Following 2 Users Say Thank You to Syko Triker For This Useful Post:
    jjr2001 (Mar 25, 2020), that_other_guy (Aug 18, 2024)
  6. #14
    Aug 2018
    Very fine work JJR. 40 years ago I spent some time at Kelly AFB on a project. The Guys there in the Depot Maintenance/Overhaul sections worked sometimes on one of a kind aircraft. They always needed to build slips,clamps, jigs, etc to work on some unique part of an aircraft. You are in that Category JJR. Good job.
  7. The Following User Says Thank You to greyhoundollie For This Useful Post:
  8. #15
    jjr2001's Tools
    Thank you. The clamps are used on the CNC machine and my little manual mill. So far they have held tight everything I throw at them.
    Cheers, JR
    Back to the shop.
  9. #16
    May 2021
    Vancouver, Washington, USA
    I'd like to add that somewhere, I have seen pictures of rocker arms being used as hold down clamps. It might even been here on HMT.
  10. #17
    Download plans for milling tools.
  11. The Following User Says Thank You to Jon For This Useful Post:
    motorhead (Aug 23, 2024)
