Milling Machine Head Removal and Holding Tools
In this video Andrew Spencer is going to demonstrate how to remove a milling machine head using a modified bar and a table mount system to be able to work on the milling head in a safe clean environment that is also safe an ergonomically friendly in other words you're not going to fall off a ladder or pull it muscle when you slip because you're standing on firm ground and the unit is firmly attached to a secure table
https://youtu.be/3pKrZanVg3Q
