Thread: Milling machine mistless cooling system - video
    Milling machine mistless cooling system. By Project Havoc. 7:40 video:
  2. The Following 9 Users Say Thank You to Jon For This Useful Post:
    albertq (Apr 6, 2025), asterix (Apr 14, 2025), emu roo (Apr 14, 2025), Inner (Apr 5, 2025), mtsintra (Apr 8, 2025), nova_robotics (Apr 5, 2025), phred (Apr 5, 2025), piper184 (Apr 8, 2025), rdarrylb (Apr 5, 2025)
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    Thanks for this video and the ideas. I like you humour and you presentation style.
  4. The Following User Says Thank You to Hans Pearson For This Useful Post:
    I used to use a mister by Koolmist a big name brand in misters.
    Milling machine mistless cooling system - video-koolmist.jpg Click for full size.
    This worked well at misting coolant and that was the problem. The workshop filled with mist. Not good to breath and not what you want settling on everything in the shop. Then I saw the Fogbuster which is designed NOT to mist. I liked that idea better and made my own version. The idea is that you still mix coolant and air but designed so that you get droplets not mist.
    It is much better. I can't find the photos of my effort but here is a pic from the Fogbuster patent.
    The chap in the video didn't arrive at the best solution for his coolant reservoir. I used a container made for a water filter, it is clear so the fluid level can be seen and they are built to withstand mains water pressure with a good safety margin, they also have two connection ports.
    One thing that I liked in the video was the use of off the shelf flow controls. I made my own because I was unaware of suitable ones to buy.
    Download plans for milling tools.
