3 Attachment(s)
Milling Vise Work Stop
Nothing too special about this except it's universal compatibility with 4 different vises in my shop.
The ends of the main 3/8 diameter rod have two different threads. 5/16-24 on one end of each allows them to be used on the Wiltons which I drilled and tapped for 5/16-24. One end has 1/4-20 for use with one of my machinist vises. The other and last end has a 6mm x1mm for the newer machinist vise. Now I have two main rods for all my vises. I made one clamp from 1018 and all of the rods are just drill rod. One of the secondary rods has a brass end that is useful for very small parts that might be missed by the secondary rod holders. It is just threaded on to the rod. I will probably make another clamp if the need arises.
Cheers, JR
Thanks jjr2001! We've added your Milling Vise Stop to our Vises category,
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/homemade-milling-vise-stop">
<img src="/uploads/157381/homemade-milling-vise-stop.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/homemade-milling-vise-stop">Milling Vise Stop</a>
<span> by <a href="http://www.homemadetools.net/builder/jjr2001">jjr2001</a></span>
</div>
<div class="tags">tags:
<a href='http://www.homemadetools.net/tag/vise'>vise</a>, <a href='http://www.homemadetools.net/tag/stop'>stop</a> </div>
</div>
</div>
</div>
I'd venture any vise suitable for a machine incomplete with out means for a part stop. Some table stops are too short or lack adjustment to project in-between the jaws; especially those dependent on tee-slots.
A good plan, doubling usage by two separate thread sizes.
You've done it again jjr2001.
Thanks TM51. The stop has already been put to use in the shop. I have found that my rod clamp is a bit too large for small pieces so my next change will be to make a second clamp that places the rods closer together and make it a bet thinner for an easier grip with the locking allen cap screw.
Cheers, JR
