Episode 3 up Now, hope you like it.
Cheers.
https://youtu.be/3z3jLfe65yU
Cheers.
Hi Aussie, nice conversion,very professional. I have converted my 10 inch lathe to treadmill and am in the process of converting a metal bandsaw.I have tried using a cheap scr and bridge rectifier but could not get a clean signal-brushes arced. I have used a control from KB but very expensive. Couldn’t catch your link to the control you used can you enlighten me?
Dick
Thanks The Aussie Shed! We've added your Mini Lathe Motor to our Lathes category,
as well as to your builder page: The Aussie Shed's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-mini-lathe-motor"> <img src="/uploads/226541/homemade-mini-lathe-motor.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-mini-lathe-motor">Mini Lathe Motor</a> <span> by <a href="https://www.homemadetools.net/builder/The+Aussie+Shed">The Aussie Shed</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/lathe'>lathe</a>, <a href='https://www.homemadetools.net/tag/motor'>motor</a> </div> </div> </div> </div>
you could try adding smoothing capacitor and bleed down resistor after the rectomfrier to clean up the dc :)
