Results 1 to 1 of 1
Thread: Model steam engine cylinder block stud making
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    Been a while since I’ve lasted posted, but have started back in the workshop after a long break.
    I decided to make the cylinder block studs for my 3”scale Foden steam wagon and thought I would share the process I use.
    There are three sizes and different lengths to suit the various items that need to be clamped to the block. The studs are variations of BA and made from stainless steel.
    As I have a 5C collet system with a Acrogrip lever operated closer this speeds up the production of the studs. In conjunction with a Dickinson tool post I am able to use two individual tools in two tool holders at once to face and chamfer the stock. This also sets the datum length for the thread to be cut using the collet face
    To cut the threads I prefer to use a Coventry die head however I only had a 4BA and 2BA set of chasers so the standard split die was used to cut the 5BA studs.
    1/8” diameter stainless steel was used and a length was cut into four pieces so a stud could be cut on each end and then cut off to complete the second thread. Using this method allows 8 studs at a time to be produced.
    Once the first thread is completed on each end of the stock it is transferred to the vice and cut with a hacksaw. A line is marked on the vice jaw to speed up this cutting process.
    l modified the Acrogrip to accept my backstop that fits normally into the lathe spindle bore, the second operation can then be cut with the stud up against the stop and using the same process cutting, the stud can be machined to length and the second thread cut.
    Hopefully the photos will help the explanation.
    Model steam engine cylinder block stud making-img_9419.jpegTwo tools for facing and chamfering which also sets thread length.
    Model steam engine cylinder block stud making-img_9420.jpegUsing a tailstock die holder and the face of the collet as a stop.
    Model steam engine cylinder block stud making-img_9422.jpegMark on vice to aid cutting to cut length.
    Model steam engine cylinder block stud making-img_9421.jpegMachined and cut studs waiting second operation.
    Model steam engine cylinder block stud making-img_9425.jpegSelection of 5BA studs different cut lengths.
    Model steam engine cylinder block stud making-img_9424.jpegLinshing stock so it fits collet
    Model steam engine cylinder block stud making-img_9426.jpegAcrogrip lever operated collet closer modified to accept backstop.
    Model steam engine cylinder block stud making-img_9427.jpegCompleted 2BA and 5BA studs.
    Model steam engine cylinder block stud making-img_9429.jpeg Model steam engine cylinder block stud making-img_9428.jpeg Studs fitted to cylinder block.
    I hope this will be of interest and thank you for viewing
    The Home Engineer
  2. The Following 4 Users Say Thank You to thehomeengineer For This Useful Post:
    emu roo (Dec 16, 2025), hotwatermike (Dec 17, 2025), Jon (Jan 2, 2026), thevillageinn (Dec 21, 2025)
