Results 1 to 5 of 5
Thread: Modification of a tap wrench
    Sep 2013
    Karl_H's Tools
    My usual method of using a tap on the lathe was to chuck the tap in the drill chuck, then turn the lathe by hand until the tap started to turn in the chuck. This would get the tap started straight and deep enough that I could then use a traditional tap wrench. However, I only have a couple inches of swing, so it was hard to use the traditional tap wrench.
    I already have a tailstock die holder that has worked really well, so I found a way to adapt that to tapping.
    One of the Big Box places had a tap wrench that had 1 inch across the flats for a hex wrench, a hole for a 1/2 inch socket, and a hole for a 1/4 inch tommy bar.
    I turned down the 1" hex to a 1" circle so I could mount the wrench in my tailstock die holder. If needed, I can still use the 1/2 in socket wrench or the tommy bar. The 1" wrench seems like an invitation to break a tap any way.
    Before I turned down the hex, I used the hex to index dimples at the proper level so my tailstock die holder could keep the wrench from turning.
    I used a 1/2 copper coupling, split length wise, as a perfect fit for soft jaws to grab the threads on the tap wrench so I didn't mar them while doing the interrupted cuts on the hex.
    The first photo shows the dimples made while the end was still a 1" hex - you can also see the original hole for a tommy bar.
    The second photo shows the tap wrench mounted in the tailstock die holder, ready to go.
    This wrench works for #4 through 1/4 taps. They offer another for 1/4 - 1/2 taps, but I don't know if it still has a 1" hex or something larger.
  2. The Following 14 Users Say Thank You to Karl_H For This Useful Post:
    baja (Apr 29, 2020), bruce.desertrat (Apr 28, 2020), elk-a-holic (Nov 12, 2024), emu roo (Dec 23, 2022), FEM2008 (May 3, 2020), JoeH (Apr 29, 2020), Jon (Apr 30, 2020), nova_robotics (Dec 23, 2022), Paul Jones (Apr 29, 2020), rlm98253 (Apr 28, 2020), Sleykin (Jan 1, 2023), sossol (Apr 28, 2020), Toolmaker51 (Dec 24, 2022), uv8452 (Nov 12, 2024)
    JoeH's Avatar
    Mar 2018
    Great idea! Many thanks.
  4. The Following User Says Thank You to JoeH For This Useful Post:
    Karl_H (Apr 29, 2020)
    May 2014
    Del Mar, California
    Paul Jones's Tools
    A photo of tap wrench in accrual use would help with your final explanation. Thank you
    Sep 2013
    Karl_H's Tools
    A photo of tap wrench in actual use would help with your final explanation. Thank you
    Not really "actual use" since the threads were cut last week, but this is the set up.
    I use the tommy bar in the tailstock die holder and either my hand on the chuck or my spindle wrench to turn the part.
    Hope this helps.
  7. The Following User Says Thank You to Karl_H For This Useful Post:
    Supporting Member elk-a-holic's Avatar
    Jan 2016
    I like the way you present this idea. No u tube time wasting yacking. Just usefully info
  9. The Following User Says Thank You to elk-a-holic For This Useful Post:
    Karl_H (Nov 12, 2024)
