Results 1 to 6 of 6
Thread: Modified broom & handbrush
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    Probably a lot of us have done this, cut pieces off a broom, or lengthened the handle of a hand brush, but a search revealed nothing.
    I donít mind bending down to use a dustpan, but crawling about on hands and knees to get in all the corners and behind boxes etc is a pain, itís getting hard to stand up again! As I hate debris beneath my feet, I use these more than once every working day. I know that I should tidy up when I have finished but usually go on until too tired, so clean up is usually effected the following morning.
    Also, I have cut off all but 4 tines from a spring rake, for the garden.
    500 Tool Plans
  2. The Following 3 Users Say Thank You to Philip Davies For This Useful Post:
    Frank S (Jun 21, 2022), thevillageinn (Jun 17, 2022), uv8452 (Jun 16, 2022)
    Supporting Member mr mikey's Avatar
    May 2022
    Michigan
    I know what you mean about getting up. Sometimes when working on a project and a bolt or drill bit falls on the floor and rolls under the bench I use a magnet on a small shaft that extends to retrieve an item. It saves the old bones and makes life a little easier. Mr. Mikey.
    Homemade Tools eBooks
  4. The Following User Says Thank You to mr mikey For This Useful Post:
    Philip Davies (Jun 21, 2022)
    Thanks Philip Davies! We've added your Broom and Hand Brush Handles to our Cleaning category,
    Magnets on a telescoping wand can be very useful but often nothing quite fits the bill as well as a narrow broom or hand brush with an extended handle for retrieving that dropped brass screw from behind or under something, or cleaning from around table legs close to a wall
  7. The Following User Says Thank You to Frank S For This Useful Post:
    While magnets are dependable; brushes don't give a whit how material identifies itself.
  9. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    Philip Davies (Jun 27, 2022)
  10. #6
    Dec 2015
    Reading, Berks, UK
    I have just dropped a tray of ball bearings! I discovered that they weren’t all steel, after all!
    Tube Bender Build Guide
