More of my tools
10 Attachment(s)
9 Attachment(s)
Thanks for posting these. I've been working on indexing them today.
<div id="blocks">
<div class="block b1 pngfix"><div class="bimg"><div><a href="/bushing-drivers"><img src="/images/thumb/3/bushing_drivers.jpg" alt="Bushing Drivers"/></a></div></div>
<div class="head pngfix"></div><div class="left pngfix"></div><div class="right pngfix"></div>
<div class="blockover b1 pngfix"><div class="title"><a href="/bushing-drivers">Bushing Drivers</a><span> by <a href="/builder/Rob+G">Rob G</a></span></div>
<div class="tags">tags: <a href="/tag/bushing">bushing</a></div>
</div>
</div>
<div class="block b1 pngfix"><div class="bimg"><div><a href="/dial-indicator-holder"><img src="/images/thumb/3/dial_indicator_holder.jpg" alt="Dial Indicator Holder"/></a></div></div>
<div class="blockover b1 pngfix"><div class="title"><a href="/dial-indicator-holder">Dial Indicator Holder</a><span> by <a href="/builder/Rob+G">Rob G</a></span></div>
<div class="tags">tags: <a href="/tag/machining">machining</a>, <a href="/tag/mill">mill</a></div>
</div>
</div>
<div class="block b1 pngfix"><div class="bimg"><div><a href="/die-holder-plans"><img src="/images/thumb/3/die_holder_plans.jpg" alt="Die Holder Plans"/></a></div></div>
<div class="blockover b1 pngfix"><div class="title"><a href="/die-holder-plans">Die Holder Plans</a><span> by <a href="/builder/Rob+G">Rob G</a></span></div>
<div class="tags">tags: <a href="/tag/machining">machining</a>, <a href="/tag/die">die</a></div>
</div>
</div>
<div class="block b1 pngfix"><div class="bimg"><div><a href="/homemade-pressbrake"><img src="/images/thumb/3/homemade_press_brake.jpg" alt="Homemade Press/Brake"/></a></div></div>
<div class="blockover b1 pngfix"><div class="title"><a href="/homemade-pressbrake">Homemade Press/Brake</a><span> by <a href="/builder/Rob+G">Rob G</a></span></div>
<div class="tags">tags: <a href="/tag/brake">brake</a>, <a href="/tag/press">press</a></div>
</div>
</div>
<div class="block b1 pngfix"><div class="bimg"><div><a href="/inserted-cutters"><img src="/images/thumb/3/inserted_cutters.jpg" alt="Inserted Cutters"/></a></div></div>
<div class="blockover b1 pngfix"><div class="title"><a href="/inserted-cutters">Inserted Cutters</a><span> by <a href="/builder/Rob+G">Rob G</a></span></div>
<div class="tags">tags: <a href="/tag/machining">machining</a></div>
</div>
</div>
<div class="block b1 pngfix"><div class="bimg"><div><a href="/machinist-bench-block"><img src="/images/thumb/3/machinist_bench_block.jpg" alt="Machinist Bench Block"/></a></div></div>
<div class="blockover b1 pngfix"><div class="title"><a href="/machinist-bench-block">Machinist Bench Block</a><span> by <a href="/builder/Rob+G">Rob G</a></span></div>
</div>
</div>
<div class="block b1 pngfix"><div class="bimg"><div><a href="/mill-work-stop-plans"><img src="/images/thumb/3/mill_work_stop_plans.jpg" alt="Mill Work Stop Plans"/></a></div></div>
<div class="blockover b1 pngfix"><div class="title"><a href="/mill-work-stop-plans">Mill Work Stop Plans</a><span> by <a href="/builder/Rob+G">Rob G</a></span></div>
</div>
</div>
<div class="block b1 pngfix"><div class="bimg"><div><a href="/quick-change-tool-post"><img src="/images/thumb/3/quick_change_tool_post.jpg" alt="Quick-Change Tool Post"/></a></div></div>
<div class="blockover b1 pngfix"><div class="title"><a href="/quick-change-tool-post">Quick-Change Tool Post</a><span> by <a href="/builder/Rob+G">Rob G</a></span></div>
<div class="tags">tags: <a href="/tag/milling">milling</a>, <a href="/tag/machining">machining</a></div>
</div>
</div>
<div class="block b1 pngfix"><div class="bimg"><div><a href="/radius-cutter"><img src="/images/thumb/3/radius_cutter.jpg" alt="Radius Cutter"/></a></div></div>
<div class="blockover b1 pngfix"><div class="title"><a href="/radius-cutter">Radius Cutter</a><span> by <a href="/builder/Rob+G">Rob G</a></span></div>
</div>
</div>
<div class="block b1 pngfix"><div class="bimg"><div><a href="/slitting-saw-arbor"><img src="/images/thumb/3/slitting_saw_arbor.jpg" alt="Slitting Saw Arbor"/></a></div></div>
<div class="blockover b1 pngfix"><div class="title"><a href="/slitting-saw-arbor">Slitting Saw Arbor</a><span> by <a href="/builder/Rob+G">Rob G</a></span></div>
<div class="tags">tags: <a href="/tag/saw">saw</a>, <a href="/tag/arbor">arbor</a></div>
</div>
</div>
<div class="block b1 pngfix"><div class="bimg"><div><a href="/small-ring-roller-plans"><img src="/images/thumb/3/small_ring_roller_plans.jpg" alt="Small Ring Roller Plans"/></a></div></div>
<div class="blockover b1 pngfix"><div class="title"><a href="/small-ring-roller-plans">Small Ring Roller Plans</a><span> by <a href="/builder/Rob+G">Rob G</a></span></div>
<div class="tags">tags: <a href="/tag/ring-roller">ring roller</a></div>
</div>
</div>
<div class="block b1 pngfix"><div class="bimg"><div><a href="/torch-circle-cutter"><img src="/images/thumb/3/torch_circle_cutter.jpg" alt="Torch Circle Cutter"/></a></div></div>
<div class="blockover b1 pngfix"><div class="title"><a href="/torch-circle-cutter">Torch Circle Cutter</a><span> by <a href="/builder/Rob+G">Rob G</a></span></div>
<div class="tags">tags: <a href="/tag/circle">circle</a>, <a href="/tag/cutting-torch">cutting torch</a></div>
</div>
</div>
</div>
<br /><br />
Looks like the only ones we already had listed were the portable press brake and the ball turner (although the ball turner had a video that I added).
Here's your tool page with all of the new tool listings: Rob G's Homemade Tools. I also adjusted your position on our Top Tool Builders page.
Videos -- added the ring roller to our Slip/Ring Rollers playlist. Added the refractory to our Kilns/Foundries/Forges playlist. Added the ball turner to our Homemade Ball Turners playlist. Added the radius cutter to our main Homemade Tools playlist (no radius cutter playlist yet). Added the mini press brake to our Homemade Metal Brakes playlist. Here's a link to all of our playlists: HomemadeTools.net Video Playlists.
Let me know if I've missed anything, or if you want to update any of the listings. Thanks again, it's great to get these indexed.
Thanks Rob G! I've added your Belt Grinder and Slip Roll to our Belt Grinders and Ring Rollers categories, respectively, as well as to your builder page: Rob G's Homemade Tools. Your receipt:
<div id="blocks">
<div class="bimg">
<div>
<a href="/belt-grinder-9"><img src="/uploads/36968/belt-grinder-9.jpeg" alt="Belt Grinder" /></a> </div>
</div>
<div class="title">
<a href="/belt-grinder-9">Belt Grinder</a> <span> by <a href="/builder/Rob+G">Rob G</a></span> </div>
<div class="tags">
tags:
<a href="/tag/belt-grinder">belt grinder</a>, <a href="/tag/stand">stand</a>, <a href="/tag/switch">switch</a> </div>
</div>
</div>
</div>
<div id="blocks">
<div class="bimg">
<div>
<a href="/slip-roll-3"><img src="/uploads/36972/slip-roll-3.jpeg" alt="Slip Roll" /></a> </div>
</div>
<div class="title">
<a href="/slip-roll-3">Slip Roll</a> <span> by <a href="/builder/Rob+G">Rob G</a></span> </div>
<div class="tags">
tags:
<a href="/tag/slip-roller">slip roller</a> </div>
</div>
</div>
</div>
