Results 1 to 10 of 11
Thread: Motorcyclist speeds through speed bump - GIF
Hybrid View
    nova_robotics (Jan 19, 2023), Scotty1 (Jan 19, 2023)
    Apr 2014
    Gadgeteer's Tools
    Can anyone explain physics involved?
    Supporting Member bob_3000's Avatar
    Aug 2020
    Quote Originally Posted by Gadgeteer View Post
    Ya I can, fat guy ate sh!t and his own bike hit him...luckily it only hit him once.
    bruce.desertrat's Tools
    It looks like there is a slight depression in the road at the edge of the speed bump; he didn't shift his weight towards the rear as he went over the hump, and it's really low res but it appears his wheel bent or turned a little in that depression which set him up for that endo.
    Oct 2016
    old kodger's Tools
    Quote Originally Posted by bruce.desertrat View Post
    looks much more like he was taken by surprise by the hump, when his front wheel hit it it went over no trouble but he applied the brakes, because by then only his front wheel was on the ground it locked up.....whoops, over the top.
  7. The Following User Says Thank You to old kodger For This Useful Post:
    Gadgeteer (Jan 19, 2023)
    Apr 2014
    Gadgeteer's Tools
    I think you have it. Apparently, he should have slowed down, prior to hitting the bump, instead of after hitting it. But, it, also, looked like a speed dip and bump.
  9. #7
    Aug 2020
    Pretty sure that is exactly what I said.
  10. #8
    Dec 2017
    NeiljohnUK's Tools
    Combined with the forks hitting their maximum compression travel hard enough to possibly deform and lock the tyre against the engine before twisting sideways and simply becoming a pivot.
    Apr 2013
    And don't extend your arms/hands to catch yourself!! That way leads to broken wrists, hands, arms!! Tuck & roll!!!
  12. The Following User Says Thank You to kb4mdz For This Useful Post:
    bruce.desertrat (Jan 19, 2023)
  13. #10
    Apr 2014
    Gadgeteer's Tools
    If a road surface contour can result in tossing a rider into the air when going too fast, might just as well have a shooter posted nearby to dispatch speeders. This eventuality parallels placing new roundabouts at old intersections without providing surface warnings for unsuspecting cycle riders.
