Results 1 to 6 of 6
Thread: Mowing Sudan grass - GIF
    Altair's Avatar
    500 Tool Plans
    nova_robotics (Jul 13, 2022), Rangi (Jul 6, 2022)
    I've seen some high yield fields of hay, but I guess I've always lived in the wrong part of the country to ever see any that was tall and thick enough to bale directly from the cut row without combining 2 or more rows together, except for the need to turn it over at least once for drying they almost don't even need a windrow rake
    Homemade Tools eBooks
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    I've never seen that used for hay, like they obviously are doing. We always cut sudangrass and sorghum with a combine that chopped it into silage in the field.
    About half-way through you can see where some critter trapped in the middle makes a run for it! That reminded me of cutting fields when I was younger, and all sorts of things, from bunnies to rats to snakes would come shooting out in front of the tractor as I got closer to the center and finishing.
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
    hemmjo's Tools
    Ha, yep at 13 seconds, you can see the path of the critter moving from top left to bottom right in the remaining patch.
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    When I was doing hay, I had a mower just like that.
    What causes the need to combin rows is the feed rate of the baler. I had a round baler that could run at a pretty decent speed and just worked better if I combine two cuts before feeding. The baler made 5ft x 5ft round bales.
    It is important that the cut dries nicely before being raked. That style cutter has a roller crimper which helps drying and it also helps that the cut stays nice and fluffy so it can sit and dry before being raked.
    Once that cut dries down, it compresses quite a bit. On a 2 or 3 tie bale, that cut will not need to heve a higher input volume to keep the bailer busy, but if you are making 4x4x8ft bales, probably can combine 3 or even 4 cuts to keep the baler busy.
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    Quote Originally Posted by schuylergrace View Post
    My clue that I ran over something was always the number of buzzards that appeared in the field. Snakes, rodents, rabbits, etc. were all potential buzzard food...
    Tube Bender Build Guide
