Thanks to JR I just had to make myself a set of these.
Made them from 3mm SS and ali jaws.
Attachment 24487
Now for a set of 120mm ones.
Jr you are :evil: i had other more important jobs to do :lol:
Attachment 24487
I gotta make a couple of those myself
How do I post the .DWR file for others to use?:headscratch:
Open the program you created it in and see if you can save it in a different format like .jpg .png . bmp .pdf
That i can do, but the readers can not take this file to their lazer cutter. Thise people need a .DRW or .DXL or something like that format. I can not post any of those formats
I would love a copy of the file. Personally I like to share things like this with people through my Google Drive account (free with any gmail account). I set folders there to be shareable (readable) by anyone with a link, then make sure that only things I don't mind sharing go into that folder. That way the file is available as long as I have my Google account, which I expect will be at least for the rest of my life. If you did that you could just post a link to it here. Plenty of guides online for how to make a Google Drive folder shareable if you don't know how.
But a provision within this forum software to share such files and have them hosted by the site would be preferable.
Great. I found my google Drive. 15 Gigs free. Now iwillfind out more about the”File” options.
Thanks garage nut! We've added your Twist Clamp to our Clamps category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-twist-clamp-2"> <img src="/uploads/215423/homemade-twist-clamp-2.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-twist-clamp-2">Twist Clamp</a> <span> by <a href="http://www.homemadetools.net/builder/garage+nut">garage nut</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/clamp'>clamp</a> </div> </div> </div> </div>
https://drive.google.com/file/d/1r0u...ew?usp=sharing
Lets see if this worked? :headscratch:
Can you find a working .DWG drawing
Hi, thanks a lot for the .dwg, could you tell me what does it mean "4 OFF"?
Instruction to the Lazer Cutter to cut me 4 off those items.
That is if you want 2 clamps.
I want 4 clamps at the end of the day but start off with making some proto types. If something is horribly wrong I can fix it.
We also have a min charge here so one clamp would have been less than the min charge so that is why I opted for 2 for starters.
Great, thank you very much!
