Results 1 to 4 of 4
Thread: Mystery cable installation process - GIF
  2. The Following 5 Users Say Thank You to Jon For This Useful Post:
    baja (Aug 21, 2019), dubbby (Aug 18, 2020), Midwestern640 (Aug 20, 2019), Miloslav (Aug 20, 2019), Seedtick (Aug 20, 2019)
    Stockholm, Sweden...
    DIYSwede's Tools
    Long shot: -Re-lining a leaking sewage/ drain tunnel?
    Seems like the flat ribbon feeds through and around the perimeter and (perhaps get heat-welded or just)
    zip-locked to the previous turn, making a tight liner, albeit with a smaller section than the tunnel itself...
    Feb 2019
    clavius's Tools
    That would be my guess as well. One of the comments mentioned a product called "SRP" and some judicious googling got me to this, that is perhaps the same thing or very similar:
    https://www.conteches.com/pipe/steel...rpe-pipe/sprpe
  5. The Following 3 Users Say Thank You to clavius For This Useful Post:
    DIYSwede (Aug 21, 2019), dubbby (Aug 18, 2020), Jon (Aug 21, 2019)
    DIYSwede's Tools
    Thanks, Clavius! Excellent link. -So that's why the tube's dia is less than the surrounding concrete culvert,
    to have grout pressure injected between it and the liner (then itself probably filled to resist the grout's pressure).
  7. The Following 2 Users Say Thank You to DIYSwede For This Useful Post:
    clavius (Aug 24, 2020), dubbby (Aug 18, 2020)
