Have you tried lathes.co?
Lathes + Machine Tool Archive
Vintage Machinery might be a good resource, too VintageMachinery.org | Welcome
Steved53 (Sep 11, 2018)
Hi Steve,
It looks like a Randa lathe: Randa Lathes
If you read the article, you'll see that they were basically rebranded and copied by other manufacturers in hte first half of the 20th century.
I have a similar one that I took into bits and is awaiting cleaning, painting and rebuilding....
PJs (Sep 12, 2018)
Hi Steve,
Your old lathe looks a lot like my 1932 Sheldon; same drive counter shaft setup and reduction gear in the head stock. The Sheldon use flat belts instead of v-belts and the previous owner sadly lost all the thread cutting gears. I found sketches and drawings of my Sheldon on Vintage Machinery. It is indeed a labour of love to restore these machines and worth it.
Steved53 (Sep 17, 2018)
Thank you everyone who suggested things. I looked on lathes.co and checking makes alphabetically, I found the Corbett was a close match. ( At least it was a 'C', saved me checking pictures up to 'Z'.)
I then e-mailed Tony at lathes.co.uk and he confirmed it is a Corbett/Winfield/Granville with a few upgrade modifications to the carriage and cross slide.
Now I just need to overhaul it and use it.
Steve![]()
