Results 1 to 7 of 7
Thread: Mystery manufacturing process - GIF
    May 2024
    Those look like 10KV resisters. 5ppm power resisters to me.
    But the video looks to be deceivingly shot out of sequence, The part where the flame is heating while the pincer spins the wire while a nichrome wire is wound around creating the red hot blob would be the first part the second stage is where you see the yellow sleeve on the wire with the blob being dropped down then the blob is pulled into the sleeve the first of the video should be the last of it
    Or at least that is the way I am looking at it I'm open of other theories
  3. The Following User Says Thank You to Frank S For This Useful Post:
    Ralphxyz (Jun 23, 2024)
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    It could also be some sort of other sealed component (reed switch, indicator, high temperature sensor) - I don't know, can't really tell. There is a lead on both ends...
  5. The Following User Says Thank You to BuffaloJohn For This Useful Post:
    Frank S (Jun 16, 2024)
    Lake Tahoe
    IntheGroove's Tools
    The torches are heating up glass tubes...
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    Quote Originally Posted by IntheGroove View Post
    That is why I thought of reed switches...
    But some other parts come up:
    NTC Thermistors
    Fuses (found fuses that were just glass tubes sealed
    Capacitors (was surprised to learn about hermetically sealed tantalum capacitors in a glass tube)
    Diodes (the good ol' 1N914 is a classic glass packaged diode from the early days)
    High voltage resistors (Frank S mentioned this one)
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    I'm pretty sure those are short LED filaments being prepped to go into a specialty lamp of some sort. I have a bunch of them in various sizes in my parts bins, and they are good for lots of projects.
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
  9. The Following User Says Thank You to schuylergrace For This Useful Post:
    BuffaloJohn (Jun 18, 2024)
  10. #7
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    Quote Originally Posted by schuylergrace View Post
    Winner! I have seen those as well...
  11. The Following User Says Thank You to BuffaloJohn For This Useful Post:
    schuylergrace (Jun 18, 2024)
