Results 1 to 7 of 7
Thread: Mystery manufacturing process - GIF
    May 2024
    nova_robotics (Jul 31, 2024)
    Lake Tahoe
    IntheGroove's Tools
    Ham and swiss on rye...
    Sep 2015
    Kansas
    Probably making McNuggets.
  5. The Following User Says Thank You to Toolguy For This Useful Post:
    bob_3000 (Jul 27, 2024)
    Apr 2021
    They are processing latex rubber sheet.
    Marion, Iowa
    metric_taper's Tools
    Is the opening thumbnail photo of what appears to be a pile of chicken skins, misleading? Then what appears to be semi frozen blocks of unknown protein.
    I'm confused, but if latex rubber is being made, it has that appearance in the end video, where either coloration is being added, or some sort of flavor-ent additives, and this is Jerky of some sort of ethnic consuming group, like 'Smokey-joe' beef sticks here in the states. Seems that would be a grinding and extrusion process if food manufacture. I know 'nuting'.
    Differential rollers? Is that used for mixing thick materials like this sort of rubber?
    Dec 2014
    South Dakota
    KustomsbyKent's Tools
    While the exact material is unknown to me, the exact same equipment is used in processing rubber, and preparing it for molding. I'm assuming this is either latex or a raw rubber. The drums press and mix it into a smooth mixture. Then it would later be cut into sizable pieces for a molding process, as rubber needs to be cured at high temperatures to set it.
    I have been in rubber processing/manufacturing plants in both the US and in China, so I've seen that first hand. In China, they were making parts for products we had designed. After the rubber is processed on those drums, then it is cut into strips, and then cut to fit the plate molds. Workers manually place the strips of raw rubber in the mold, then they are pressed and heated at the same time to cure the rubber, and then the worker removes the molded part and reloads it. Hot and repetitive work, but you can mold complicated parts with fairly simple tooling.
  9. The Following 2 Users Say Thank You to KustomsbyKent For This Useful Post:
    Frank S (Jul 28, 2024), lassab999 (Jul 29, 2024)
  10. #7
    Sep 2015
    Kansas
    The beginning material is clearly chicken parts, therefore, they must be making rubber chickens.
  11. The Following 3 Users Say Thank You to Toolguy For This Useful Post:
    Floradawg (Jul 31, 2024), nova_robotics (Jul 31, 2024), wood_1 (Jul 29, 2024)
