https://youtu.be/8QYeGWEv1SA
Thanks fergiomaria! We've added your Sheetmetal Bender to our Metalworking category,
as well as to your builder page: fergiomaria's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-sheetmetal-bender-25"> <img src="/uploads/259178/homemade-sheetmetal-bender-25.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-sheetmetal-bender-25">Sheetmetal Bender</a> <span> by <a href="https://www.homemadetools.net/builder/fergiomaria">fergiomaria</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/sheetmetal'>sheetmetal</a>, <a href='https://www.homemadetools.net/tag/bender'>bender</a> </div> </div> </div> </div>
it looks like a handy small tray maker well done are there plans available ? i talk english
HO MESSO ALCUNE MISURE PER REALIZZARE IL CARRELLO CHE È BASE DI PARTENZA PER COSTRUIRE TUTTA LA PIEGATRICE. SE HAI BISOGNO DI ALCUNE MISURE FAMMELO SAPERE
It's a good video, and maybe enough detail to duplicate one, step by step like the presentation, some portions are too high a viewing speed. More noticeable at the end, trying to see how bent parts look.
I prefer the standard methods of apron & fingers/ bar, or presses with punch & die tooling.
Rollers have a place too. To date, those have been to turn edges of contours, like duct flanges, beads, lip of a fender, fair compound surfaces together, etc. Can't visualize standing up deeper edges typical in box type forms by rolling; seems a lot deformation will occur in the un-clamped side.
Aside from reduction of material needed (compared to a big plate for an apron), I'm not recognizing a benefit in rolling to achieve shallow standard corners. What am I missing?
The single major advantage to rolling is the contact area while forming is miniscule compared to an apron & finger clamping break. allowing for lighter construction less bulk and easier to stow away in a small shop where space is always a premium, if a press break using punch and die set up then you need punches the same length as the inside of the box the same thing holds true for finger clamp apron folding breaks And even with a roller form you need something to fit between the 2 sides and tall enough to clamp the base material.
Now here is where a small sheet metal roller form can excel over an apron and finger or a press break for a press break for air bending the V width needs to be at least 5 times as wide as the metal thickness and the minimum flange width should be 6 times the material thickness. If we take for example 20ga takes 2.2 tons of force with a V width of 5/16", the minimum v width for 20 ga is 1/4" but it takes 2.9 tons of force. 18ga a common thickness for restoring old cars requires 5.4 tons with a 1/4" V while the recommended V for 18ga is 3/8" With a roller the force is greatly reduced to 100s of pounds force as opposed to tons, since you are only rolling a slight increase in the forming angle on each pass you need multiple passes through and the less of a bend angle you try to make on each successive pass reduces the possibility of deformation of the free edge of the flange. If you roll over a stiffening edge to the flange prior to making the box side, you reduce that even further. plus, it removes the sharp edge and may allow you to use lighter ga material.
I like his idea, since it is very similar in operation to a bead roller so far as the required strength of the machine is concerned, the major difference in unlike a bead roller the material remains stationary and the roll forming process is more akin to a multi station roll forming machine consider each pass as another rolling station.
Congratulations fergiomaria - your Sheetmetal Bender is the Homemade Tool of the Week!
This is a unique take on a very common tool build. We'd be interested to see more construction details, and possibly some other applications of this same concept.
Front Alignment Pedestals by Frank S
Mallet by Mazay
Kant Clamps by craig9
Lawnmower Starter by ercaneverything
Camber Gauge Mount by Frank S
Hand Powered Chainsaw by My MiniCrafts
Nickel Plating Method by celsoari
Differential by fawabros
Thread Chaser by Frank S
Miter Gauge by hwmrob
Vise Mounted Ring Roller by Improvised DIY
Car Jack by troyhaack
Domino Jig Fence by Carmonius Finsnickeri
Center Stand by th62
Lifting Tool by fergiomaria
Lug Bolts by hemmjo
Steel Nose Bandsaw Sled by Make Things
Collet by Cazual Haze
fergiomaria - you'll be receiving a $100 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
This is your 2nd Homemade Tool of the Week win. Here are both of your Homemade Tool of the Week winning tools. Congrats again :thumbsup:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/semplice-pantografo-per-tornio-simple-lathe-pantograph-93432#post211937"> <img src="/uploads/256647/homemade-pantograph-10.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/semplice-pantografo-per-tornio-simple-lathe-pantograph-93432#post211937">Pantograph</a> <span> by <a href="https://www.homemadetools.net/builder/fergiomaria">fergiomaria</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/pantograph'>pantograph</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/nuovo-modo-di-piegare-le-lamiere-96557#post222881"> <img src="/uploads/259178/homemade-sheetmetal-bender-25.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/nuovo-modo-di-piegare-le-lamiere-96557#post222881">Sheetmetal Bender</a> <span> by <a href="https://www.homemadetools.net/builder/fergiomaria">fergiomaria</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/sheetmetal'>sheetmetal</a>, <a href='https://www.homemadetools.net/tag/bender'>bender</a> </div> </div> </div> </div>
My only comment is that it is a very slow method. A normal style of folder would be much faster.
Grazie Jon per il tuo duro lavoro, sono contento che le mie idee possono piacere a molti.
La mia mail per il premio settimanale è giovannimaria.ferrari@gmail.com e la scelta è PayPal.
Ringrazio anche tutta la comunità
Great, paid. Congrats again :)
