If your engines oil pump drive is shared with the distributor drive an old distributor shaft can be used to prime the oiling system before starting a newly rebuilt engine, by simply attaching the shaft to an electric drill.
Thanks pursang! I've added your Oil Pump Primer to our Engine category, as well as to your builder page: pursang's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="/oil-pump-primer-3"><img src="/uploads/77536/oil-pump-primer-3.jpeg" alt="Oil Pump Primer" /></a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="/oil-pump-primer-3">Oil Pump Primer</a> <span> by <a href="/builder/pursang_2">pursang</a></span> </div> <div class="tags"> tags: <a href="/tag/oil-pump">oil pump</a>, <a href="/tag/distributor">distributor</a> </div> </div> </div> </div>
Thanks Ken.
Just ensure you are turning it the correct way. Some oil pumps turn Counterclockwise, some Clockwise.
What a brilliant idea, having just rebuilt my series 2a landrover engine, I've been stressing about turning it over dry for quite some time.
Thank you ......!!
Norm.
Definitely something I should've mentioned in the post, the direction should follow the engines firing order,
installing a mechanical oil guage with an opaque oil line would also allow you to observe the flow of oil and let you know the kind of oil pressure your drill will produce.
Your welcome Norm
