Results 1 to 8 of 8
Thread: One way grinding wheel balancer
  1. #4
    Supporting Member mattthemuppet's Avatar
    Aug 2016
    Walla Walla, WA USA
    mattthemuppet's Tools
    thanks for pointing this out to me, good to have another option and shouldn't be too tricky to machine one either. AFAIK they use a similar system for balancing surface grinder wheels, although in that case they're hubs which the wheel is mounted to and then mounted to the spindle. You can do a "poor mans" version by drilling and tapping holes around the periphery of the arbor then attaching thick washers with screws at the light point.
    I also balanced a couple of treadmill motor flywheels using a DIY jig and skateboard bearings, then drilling a divot at the heavy point until the flywheel stopped randomly at all points around its diameter. Worked really well and got rid of a bad vibration on my lathe.
  2. The Following User Says Thank You to mattthemuppet For This Useful Post:
    Paul Jones (Sep 18, 2016)
