Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Organizer for drills and threading tools
    Thanks Vyacheslav.Nevolya! We've added your Tap and Drill Bit Organizer to our Storage and Organization category,
    as well as to your builder page: Vyacheslav.Nevolya's Homemade Tools. Your receipt:
  2. #12
    Quote Originally Posted by Hemi View Post
    This is exactly what I was referring too! -I had to ask as the way you typed it out makes the most sense in how the holder would work on your bench or in a cabinet built for suck type holders.... (which one day will be my plan!)
    -I'm not an old guy, really, BUT I'm on a TON of meds myself, and those pill vials in the standard sizes I get are saved for such tasks! I put all my "supply" in them, and only keep one of each item (drills and taps) out on the bench! Till it either A. wears out, or B. I break it..... LOL I plan to make a rotary rack to have each lid fastened to a board, on a octagon center, to spin with the same size bottles on every board around the octagon!
    Rotating racks, especially those with several tiers, one above the other, are great - especially if they can be placed in a corner. Efficiently using the space in a corner is not an easy thing to do and rotating racks work best. That's why you often see them in kitchen corner cabinets. All my corners have lazy susans, some purchased and some homemade.
    However, in this case I'm not sure it's best. Since in this case you're storing material that will be only very occasionally accessed, the relatively low storage density of a rotating rack may not be warranted. A box or drawer with the vials closely packed but having the labeled tops visible may be a better use of space.
    My box of tightly packed vials is covered with several other boxes that must be moved to access the vials yet I need to access it so seldom that moving stuff to get to it is not annoying.
    Of course, my shop is tiny and really crowded; you may have enough space that this is not a concern.
  3. The Following User Says Thank You to mklotz For This Useful Post:
    Moby Duck (May 30, 2017)
  4. #13
    Jan 2016
    Moby Duck's Tools
    [QUOTE=mklotz;93832]Rotating racks,
    I like your idea of storing the vials vertically in a box or drawer but beware of only labeling the lids. Make sure that you label the sides of the vial as well because there is a good chance of mixing up the lids. Found out the hard way with spice jars labeled only on the lid. What a disaster that was. Now I would never just pull a tap or drill from a vial and not check it, but it would still be annoying checking all of the other vials if you found one with the wrong crossed over lid.
    p.s. Just found your earlier post on colour coding the labeling and I like that idea too.
  5. #14
    [QUOTE=Moby Duck;93871]
    Rotating racks,
    Thanks for the warning but I can't remember ever having two of the vials open at the same time. In addition, my OCD is strong when it comes to keeping things in their proper containers.
    There's a more common mistake to watch for when threading. Taking the tap and clearance drill (both of similar sizes) to the mill at the same time can easily lead to drilling the hole to be threaded with the latter. I've only actually done it once but have come close on several occasions.
  6. #15
    [QUOTE=mklotz;93879]
    Especially true with the size taps you are most likely to use in model making
    Download plans for drilling and drill presses.
  7. The Following User Says Thank You to Frank S For This Useful Post:
    olderdan (May 31, 2017)
