Results 1 to 4 of 4
Thread: Paint Shaker from a Brass Tumbler
    TigerCreek's Avatar
    Feb 2019
    TigerCreek's Tools
    This is a simple modification of a brass tumbler that will make it able to effectively shake paint. The key is changing (slowing) the motor speed.
  2. The Following 4 Users Say Thank You to TigerCreek For This Useful Post:
    Altair (Apr 20, 2020), Jon (Apr 23, 2020), Moby Duck (Apr 21, 2020), rlm98253 (Apr 21, 2020)
    Thanks TigerCreek! We've added your Paint Shaker to our Painting category,
    as well as to your builder page: TigerCreek's Homemade Tools. Your receipt:
    Jul 2019
    It will be interesting to see if it shakes enough to bring the pigment that settles on the bottom of the can to the surface.
    Good simple design if it works but I think it’s just a slower vibration rather than a good shake.
    Cheers and good luck.
    TigerCreek's Avatar
    Feb 2019
    TigerCreek's Tools
    If it doesn't seem aggressive enough for your particular application, two simple things that can be done to increase the "shaking".
    One, replace the stock springs with longer or weaker springs.
    Two, increase the amount of offset weight on the shaft.
    I used this fabrication because it worked well for my particular needs, and it is a very easy modification.
