The Panavise base, shown here mounted on a bench hook*,
has a very DIY-friendly clamping arrangement to hold the vise. The clamping cotters inside the green sphere are each equipped with half of a 5/8" hole. When the red knob is tightened, these cotters clamp the 5/8" rod on the base of the vise and lock the vise in both azimuth and elevation. No nasty proprietary threads or sizes, just a simple arrangement that works and works very well.
It didn't take me long to take advantage of this arrangement. A 5/8" rod attached to my matched sliding vises...
made them much easier to use - especially so when soldering.
I've meant to further exploit the simple clamping in this very useful base and today I got an opportunity to make this...
A 5/8" steel rod is threaded 12 x 1 mm on the left end and 3/8 x 24 on the right end. (That should provide a bit of confusion for my heirs when they discover it.)
The 12 x 1 allows me to mount any of the Unimat chucks, 3jaw, 4jaw, and drill...
and the 3/8 x 24 accommodates the watchmaker's vise...
If you have a Panavise, I heartily recommend getting the base...
https://www.amazon.com/PanaVise-305-...=panavise+base
and give some thought to which of your tools can be improved by mounting them thereto.
Damn, it's nice to have a shop and a lathe. I only thought of this part this morning in the shower. It's not made or sold anywhere but by this afternoon I have one in my hand.
* The bench edge clamp supplied with the base puts the Panavise too close to the edge of the bench. There is no support for one's forearms so it's difficult to hold the hands steadily enough to do fine work. By moving the Panavise back from the edge by use of the bench hook, the forearms are supported and steadier work is the result.
