Thread: Pedal-powered bench grinder - video
    Pedal-powered bench grinder by Sek Austria. 10:51 video:
    Antique hand-cranked grinding stone - GIF
    1906 pedaled roller skates - photo and patent
  2. The Following User Says Thank You to Jon For This Useful Post:
    IAMSatisfied (Mar 2, 2019)
    Supporting Member IAMSatisfied's Avatar
    Apr 2017
    The desolate ranch country of Northeastern corner of New Mexico, USA
    IAMSatisfied's Tools
    I really like the pedal mechanism. Thanks for sharing!
    It looks to me that the wheels don't rotate true, probably due to using galvanized pipe for the shaft. Plumbing pipe is not very straight to begin with, and I'm sure welding on it only makes matters worse. Using solid steel for the shaft would only improve the trueness of the wheels rotation.
    Another addition that would make this good for heavier grinding would be incorporating a flywheel for inertia.
  4. The Following User Says Thank You to IAMSatisfied For This Useful Post:
    Andyt (Mar 3, 2019)
    Using the coaster sprag was a good move. I agree adding a flywheel for smoother running would be nice
