Results 1 to 4 of 4
Thread: PEPCON chemical plant explosion - GIF
    Altair's Avatar
    Pacific Engineering and Production Company of Nevada (PEPCON) chemical plant explosion in 1988. The plant manufactured ammonium perchlorate used in rocket boosters. The disaster claimed two lives, injured 372, and caused $100 million in property damage.
    Aluminum factory explosion - GIF
    German chemical plant explosion - GIF
    Solvent factory fire - GIF
    Chemtool factory explosion - GIF
    Steel plant explosion - GIF
    mwmkravchenko (Oct 16, 2021)
    Stockholm, Sweden...
    DIYSwede's Tools
    There was also some fuel added to nearly 4000 metric tons of oxidizer:
    assuming a welding-caused small fire start and subsequent ignition of a natural gas leak from a 30+ years old pipeline running below,
    which then ruptured from the first blast adding LNG to the last blasts.
    "The facility also had a 16-inch (41 cm) high-pressure gas transmission line running underneath it,
    carrying natural gas at 300 psi (2.1 MPa) gauge pressure."
    Yield was 1 TJ, or equivalent to 1/4 kT of TNT,
    putting it at # 11 amongst the largest accidental (non-nuclear) man-made explosions (yet).
    About half of the Beirut explosion in Aug, 2020 (getting in at # 6).
    3.5 on the Richter Earth Quake magnitude (logarithmic) scale.
    Link:https://en.wikipedia.org/wiki/PEPCON_disaster
    https://en.wikipedia.org/wiki/Larges...EPCON_disaster
  4. The Following 5 Users Say Thank You to DIYSwede For This Useful Post:
    Altair (Oct 16, 2021), bruce.desertrat (Oct 16, 2021), mwmkravchenko (Oct 16, 2021), that_other_guy (Oct 16, 2021), verticalmurph (Oct 16, 2021)
    Supporting Member Fluffle-Valve's Avatar
    Oct 2015
    Duston, Northampton, UK
    Wow, Just Wow.Is that a shock wave you see going across the ground?
    I have a 1972 Land Rover Series III Truck Cab/Pick-Up and a 1962 Land Rover Series 2a Carawagon Camper.
    Mar 2018
    Quote Originally Posted by Fluffle-Valve View Post
    Yes and it took 10 seconds to reach the camera
