plywoodworking #trackguide #circularsaw
I build simple but accurate track guide. This is multifuction track guide you can use for circular saw, & router. Cut use circular with this track very accurate and you not worry about the blade depht, you can use maximum blade depht. Easily for make perfect slot with router. Cheap, simple and easy for build but give huge impact
https://youtu.be/bPeEyHvIPUs
