That gearing is likely to drastically reduce your spindle rpms so that the press can be used with a tapping attachment to thread holes. Engage it and see what the lowest rpm rate is and if it's 100 rpm or less that press should do a dandy job of threading holes, and then I highly recommend that you get the necessary bits to power thread holes because it's a very very useful technique to have available in the shop.
