Thread: Pipe bending firebox for fence posts
    Supporting Member Imabass's Avatar
    Dec 2015
    Imabass's Tools
    As seen in my other videos with the post driver, I drove 2-7/8 pipe for corner posts. Some of them are slightly off from plumb. In order to bend them to plumb, i used a propane weed burner torch. I made a simple fire box to contain the flame help prevent starting a field fire. For extra safety, i sprayed down the surrounding area with water as extra precaution.
    I simply used a metal bucket that I had. I cut the bottom out of the bucket with a grinder and also cut a hole in the bottom to insert the torch. It takes a few minutes to get the pipe red hot where it can easily be bent by hand to get it perfectly plumb. Note that you should not use a galvanized bucket due to potential for dangerous zinc fumes. I was outside and not up and close to the burner.
    Why buy it if you can build it.
  2. The Following User Says Thank You to Imabass For This Useful Post:
    Jon (Nov 2, 2016)
    Thanks Imabass! We've added your Firebox to our Heating and Cooling category,
    as well as to your builder page: Imabass's Homemade Tools. Your receipt:
