Thread: Plane conversion- scraper plane from Stanley smoother
    Carpenter & blacksmith
    Philip Davies's Avatar
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    Plane conversion- scraper plane from Stanley smoother-3314edc3-8b25-4f9c-b3e7-7d643ca7afee.jpg
    This started as a smoothing plane I’d retrieved lacking handles, irons etc, and I already have more than one already.
    Plane conversion- scraper plane from Stanley smoother-abf1c5d6-7fbe-4f28-a1a4-5a341e1178d5.jpg
    I thought I would use the existing frog as the basis for adjustment, so I made a plate to screw on to the back of the scraper frog, which is the main part of the conversion
    Plane conversion- scraper plane from Stanley smoother-8cefb11e-39d0-40c4-ac92-a8ce06e6ea6b.jpg
    The idea was to make a bridge to hold the blade down on the frog and have a central screw to flex the blade, hence the threaded insert. However, this proves unnecessary. The frog I made has a slight camber which gives sufficient rigidity, when the bridge is bolted down.
    Plane conversion- scraper plane from Stanley smoother-3132d6cf-54e7-47eb-86e7-777ce465b7ab.jpg
    Here you see the blade, bridge and other bits.
    Although I am satisfied with the result, a disadvantage is that, to sharpen the blade, I must unscrew the bolts on the bridge and the redundant central screw, and to do that, I must also remove the front tote! However, I think that I shall cut down an Allen key to access the bridge screws, and make a couple more blades, simple T shapes, without the slots. I am glad that the adjustment works satisfactorily, because although I could increase the depth of cut with a tap from a hammer, there’s no other way of retracting it.
    I might just add that I made a batch of 6 totes, because I have a couple of other planes to restore, and couldn’t be sure of the fit. This one is a bit large, but comfortable.
  2. The Following 2 Users Say Thank You to Philip Davies For This Useful Post:
    Jon (09-22-2019), threesixesinarow (09-27-2019)
    Content Editor DIYer's Avatar
    Thanks Philip Davies! We've added your Scraper Plane to our Planes category,
    Post your reply!
    Join 41,949 of us and get our 173 Must Read Homemade Tools eBook free.
