Thread: Plastic pipe deburring tool - video
  2. The Following 6 Users Say Thank You to Altair For This Useful Post:
    desbromilow (Apr 30, 2023), johncg (Apr 25, 2023), kboy0076 (Apr 26, 2023), nova_robotics (Apr 24, 2023), piper184 (Apr 25, 2023), that_other_guy (Apr 30, 2023)
    Jul 2019
    Making something to fix a nonexistent problem!
  4. The Following 2 Users Say Thank You to Wildwilly For This Useful Post:
    Gadgeteer (May 4, 2023), that_other_guy (Apr 30, 2023)
    Aug 2012
    Australia
    desbromilow's Tools
    thanks, I use a knife, and I've seen local plumbers use the back of the panel saw they used to cut the pipe.
    Aug 2018
    that_other_guy's Tools
    Only the OD?
    Why not the ID too?
    Supporting Member NeiljohnUK's Avatar
    Dec 2017
    NeiljohnUK's Tools
    I'm not sure I'd use one like that, though the taper looks ok I'll stick with my GF tool, good from 1/2" to 12" and probably bigger with thin walls. It's not just deburring that's important, cement bonding shed 80 for 100+ PSI has to be done right, the 'professionals' who installed £6M of GF in our building didn't do it right, 15 years later we're still getting bond-line failures, a combination of no taper scrape off no bond and not properly solvent cleaning so the solvent cement is sitting on mold release wax. GF visited to 'assess' the systems and ran away, no liabilities as the installers hadn't followed the manufacturers design specs or methodology, not even expansion/contraction 'U' drops...
