Results 1 to 7 of 7
Thread: Plastic recycling machine - GIF
  2. The Following 4 Users Say Thank You to Altair For This Useful Post:
    desbromilow (Jan 4, 2021), nova_robotics (Jan 4, 2021), Rangi (Mar 30, 2022), rlm98253 (Jan 4, 2021)
    jdurand's Tools
    polyethylene, extremely easy to recycle That and PET.
    Mar 2018
    Hoosiersmoker's Tools
    Same method used here all over the US but on a much smaller scale and much much slower! Ive seen pelletizing extruders with a fly knife after the cooling bath that rotates around 800 RPM to create the right sized pellets. This one looks like it's barely moving.
    Mar 2018
    West Lafayette, Indiana
    So, I see the inputs and the outputs. Can someone help me understand what’s happening in between?
    jdurand's Tools
    the plastic goes into a big screw inside that pipe and is forced through a heated section where it melts. From there it's pushed through those little holes at the end to make plastic rods like a pasta machine. They're run through a water bath to cool them, then into a chopper to make short pellets from them.
    I'm surprised they don't just have a spinning knife right at the extruder like is done with pasta.
    About 42 seconds into this video. You can see the round screw tube but it's not heated for pasta.
    Mar 2018
    [QUOTE=jdurand;173010]the plastic goes into a big screw inside that pipe and is forced through a heated section where it melts. From there it's pushed through those little holes at the end to make plastic rods like a pasta machine. They're run through a water bath to cool them, then into a chopper to make short pellets from them.
    The strands are too soft immediately out of the extruder to chop, they need to be cooled to solidify them a little. Especially HPDE is quite soft. Pelletizing isn't alway necessary either. Many extrusion processes can use flaked medium now requiring only a fine screened grinder to do the work. You could buy 10 or 12 grinders for the cost of one pelletizer, run them cheaper and process scrap considerably faster.
  8. The Following User Says Thank You to Hoosiersmoker For This Useful Post:
    jdurand (Jan 11, 2021)
  9. #7
    jdurand's Tools
    Quote Originally Posted by Hoosiersmoker View Post
    Ah, that makes sense!
