3 Attachment(s)
Poor man boring bar
Hi!
Not a great tool, in fact I modified an old boring bar in order to cut large holes in light materials.
I created a sort of guide in the lower part of the tool (10mm) , so that it can be inserted into a pre-hole drilled in the part. The cutting tool is an old broken tap grinded.
I cut a 45mm hole in 3mm aluminum with drill press, I haven't noticed any particular problems or vibrations, the guide worked well.
I don't recommend to use with drill press, the milling machine is the safest way. In particular, vibrations could easily detach the morse cone from its seat.
Attachment 34714 Attachment 34715
Attachment 34716
Thanks rendoman! We've added your Boring Bar to our Machining category,
as well as to your builder page: rendoman's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/homemade-boring-bar-28">
<img src="/uploads/232678/homemade-boring-bar-28.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/homemade-boring-bar-28">Boring Bar</a>
<span> by <a href="https://www.homemadetools.net/builder/rendoman">rendoman</a></span>
</div>
<div class="tags">tags:
<a href='https://www.homemadetools.net/tag/boring-bar'>boring bar</a> </div>
</div>
</div>
</div>
