1 Attachment(s)
PORTABLE ROUTER TABLE
i repurposed this old Towa 91/4 " saw table into a router table. I used it for many years with the original metal top with a hole cut in the centre of the blade slot. The slot & hole weakened the pressed steel top. It was & is great as a second table esp if using a bearing bit but I can clamp a straight edge for a fence when needed.
When I did renos away from home it was invaluable as the only bench router on site.
Some years back I cut the original metal top away, and replaced with thick perspex allowing above visibility, as the metal top sagged slightly under the weight of the Makita 3 hp router.
It is especially useful when used in conjunction with the B & D Workmate which expands to hold it securely but can be clamped to any secure table.
I guess many who have read my posts know I like to reuse rather than throw away.
Attachment 28020
Cheers,
Ranald
Thanks ranald! We've added your Portable Router Table to our Router Tables category,
as well as to your builder page: ranald's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/homemade-portable-router-table-2">
<img src="/uploads/220817/homemade-portable-router-table-2.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/homemade-portable-router-table-2">Portable Router Table</a>
<span> by <a href="http://www.homemadetools.net/builder/ranald">ranald</a></span>
</div>
<div class="tags">tags:
<a href='http://www.homemadetools.net/tag/portable'>portable</a>, <a href='http://www.homemadetools.net/tag/table'>table</a> </div>
</div>
</div>
</div>
