Results 1 to 7 of 7
Thread: Portable Workbench with Two Quick-Release Vices
    Dr.Al's Avatar
    Jul 2018
    Dr.Al's Tools
    This is my new portable workbench, used for clamping wood higher up than I can with the vice built in to the main workbench. Apart from the 160 mm diameter aluminium hand-wheels and some basic hardware, everything was home-made. The quick-release vice mechanisms allow the vice jaws to be slid open easily once the hand-wheels have been turned about half-a-turn anticlockwise and then they re-engage the thread when turned clockwise.
    The vice jaws are 380 mm wide and the moving jaws are coated in leather to improve the grip.
    The bench is made out of beech and American black walnut; the mechanisms and other moving parts are steel and the bearings & bushes are brass.
    The dual-screw vice allows vertical clamping of stock up to 200 mm wide and also clamping tapered stock. Both sets of jaws open to a maximum of about 300 mm.
    There's also a little edge guide that fits into a 12 mm slot in the fixed jaw of the dual-screw vice. This allows two pieces (one vertical and one lying on the bench top) to be aligned with their edges in the same position, which is useful for marking out the pins when cutting dovetails.
    The dovetail guide has a storage slot in the side of the bench with a brass clamp to hold it in place but make it very easy to remove (by turning the clamp 180 anticlockwise).
    There is a bit more detail about the design (and some higher resolution photos) on my website: https://www.cgtk.co.uk/woodwork/hand...tableworkbench.
    There is also a very detailed build log, consisting of 67 pages and more than 400 work-in-progress images on another page on the same site: https://www.cgtk.co.uk/woodwork/hand...workbench/blog.
    I've also recently added details of all the other woodworking tools and other projects I've done in the last year to my site: https://www.cgtk.co.uk/woodwork and there's an existing section with more metalworking-related projects: https://www.cgtk.co.uk/metalwork. This workbench probably involved more metalwork than woodwork, but it lives in the woodworking section of my site as that is what it will be used for. I'll try to post some of the other tools here soon.
    Metalworking projects site: https://www.cgtk.co.uk/metalwork
    Woodworking projects site: https://www.cgtk.co.uk/woodwork
  2. The Following 10 Users Say Thank You to Dr.Al For This Useful Post:
    bruce.desertrat (Apr 6, 2021), Duke_of_URL (Apr 6, 2021), Jon (Apr 7, 2021), marksbug (Apr 12, 2021), Philip Davies (Apr 7, 2021), Priemsy (Apr 6, 2021), rayh__ (Apr 6, 2021), sossol (Apr 11, 2021), toeless joe (Apr 11, 2021), volodar (Apr 12, 2021)
    Jul 2020
    Sweet !!!!!
    Supporting Member Drew1966's Avatar
    Oct 2016
    Nice Moxon vise.
    Dr.Al's Avatar
    Jul 2018
    Dr.Al's Tools
    Thanks both.
    Oct 2019
    Just went cruising around your woodwork website; very nice
  7. The Following User Says Thank You to toeless joe For This Useful Post:
    Dr.Al (Apr 11, 2021)
    Thanks Dr.Al! We've added your Portable Workbench to our Workbenches category,
    as well as to your builder page: Dr.Al's Homemade Tools. Your receipt:
  9. The Following User Says Thank You to DIYer For This Useful Post:
  10. #7
    Apr 2016
    OMG!!!!! whooda thunk it!! use round wheels for handles!!!! I hate the sliding handles!!!
