2 Attachment(s)
Power Caster
Here's a project I completed a few decades ago. I got tired from moving a rather large utility trailer around by hand, so put together his handy device. Power is supplied by a small HF 12 VDC winch, converted to chain drive by adding a sprocket to the cable spool. In/out reversing switch that came with the winch provides for reversing directions. Triangular design with split frame facilitates easy chain tensioning by sliding motor. Wheel is stolen off of a wheel borrow. Black pipe for handle. Easily moved the trailer with a full load of firewood.
Thanks Gadgeteer! We've added your Power Caster to our Trailers and Towing category,
as well as to your builder page: Gadgeteer's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/homemade-power-caster">
<img src="/uploads/241972/homemade-power-caster.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/homemade-power-caster">Power Caster</a>
<span> by <a href="https://www.homemadetools.net/builder/Gadgeteer">Gadgeteer</a></span>
</div>
<div class="tags">tags:
<a href='https://www.homemadetools.net/tag/motor'>motor</a>, <a href='https://www.homemadetools.net/tag/casters'>caster(s)</a>, <a href='https://www.homemadetools.net/tag/winch'>winch</a> </div>
</div>
</div>
</div>
I'm glade i found this power caster.
I will build this ASAP have a shop that is over packed and I need this type of tool to move equipment.
Thank you for you ingenuity.
dell
I should have mentioned that I added a bolt-on pipe receptacle to the tongue of anything I moved with the power caster. If the one-wheel caster is used with a ball, it will fall to a side.
