Results 1 to 4 of 4
Thread: Power Caster
    Apr 2014
    Gadgeteer's Tools
    Power Caster
    Here's a project I completed a few decades ago. I got tired from moving a rather large utility trailer around by hand, so put together his handy device. Power is supplied by a small HF 12 VDC winch, converted to chain drive by adding a sprocket to the cable spool. In/out reversing switch that came with the winch provides for reversing directions. Triangular design with split frame facilitates easy chain tensioning by sliding motor. Wheel is stolen off of a wheel borrow. Black pipe for handle. Easily moved the trailer with a full load of firewood.
    Attached Thumbnails Attached Thumbnails Power Caster-power-casterb.jpg   Power Caster-power-caster1.jpg
  2. The Following 9 Users Say Thank You to Gadgeteer For This Useful Post:
    Andyt (01-12-2021), baja (01-12-2021), Big-Pete (01-11-2021), dubbby (01-11-2021), Jon (01-11-2021), Priemsy (01-17-2021), rlm98253 (01-11-2021), Saltfever (01-13-2021), Toolmaker51 (01-17-2021)
    Thanks Gadgeteer! We've added your Power Caster to our Trailers and Towing category,
    as well as to your builder page: Gadgeteer's Homemade Tools. Your receipt:
    Sep 2018
    I'm glade i found this power caster.
    I will build this ASAP have a shop that is over packed and I need this type of tool to move equipment.
    Thank you for you ingenuity.
    dell
    Apr 2014
    Gadgeteer's Tools
    I should have mentioned that I added a bolt-on pipe receptacle to the tongue of anything I moved with the power caster. If the one-wheel caster is used with a ball, it will fall to a side.
  6. The Following User Says Thank You to Gadgeteer For This Useful Post:
