I needed to re-think Frank S's suggestion too. It makes perfect sense though; you cut the guide pipe at the top, as you gradually drive in the grounding rod.
They make a special bit for hammer drills just for driving ground rods. Easiest way to drive a rod in the ground is to have someone else do it. Lol. I would go by an electrial shop and ask to rent there hammer drill and their ground rod driver. I can't see them wanting that much to do that. Or find a good electrician and ask for some help on that. Also get some water to pore arround the hole as you drive it in. The water has a hydraulic effect on the rod and helps to drive it in the ground it actually pulls the rod down as you drive it in. No joke.
Jon (Dec 18, 2016), Loose Ctrl (Dec 18, 2016), PJs (Dec 19, 2016)
