Results 1 to 9 of 9
Thread: Power feeding a shredder knob
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Hi,
    My Stihl shredder is a great gardenning tool, it's powerfull and reliable, but it is inevitable that from time to time, it gets clogged...
    To fix that, you need to unscrew both of the black knobs on the front (maybe 20 revolutions each), clean the blades up, re-screw both of the knobs, start again, and sometimes, it can happen more often than desirable, you get quickly tired of screwing, unscrewing with both hands ...
    I had the idea to speed up the process, using a power screwdriver. So I needed a big socket that could fit on the knob.
    In order to check how I could do that I initially 3D modelized the knob, I was thinking doing something with my CNC out of wood.
    But I realized I had this big brass fitting sitting on a shelf, and it could do just right with "little" work.
    So I decided to go the conventional way, using my mill and my lathe. (I like it !)
    Here are some pictures of the process and eventually the final product I came up with.
    Thanks for reading !
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 11 Users Say Thank You to Christophe Mineau For This Useful Post:
    DIYer (Nov 19, 2021), Drew1966 (Nov 21, 2021), emu roo (Nov 19, 2021), Harvey Melvin Richards (Nov 19, 2021), Home-PC (Nov 21, 2021), johncg (Nov 19, 2021), Jon (Nov 21, 2021), metric_taper (Nov 21, 2021), rlm98253 (Nov 18, 2021), Sleykin (Nov 19, 2021), verticalmurph (Nov 16, 2023)
    Thanks Christophe Mineau! We've added your Shredder Blade Cover Socket to our Farm and Garden category,
    as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
    May 2015
    Tasmania, Australia
    Bony's Tools
    Couldn't you have more simply replaced the plastic capped bolts with regular bolts and used a socket in your drill? Or am I missing something?
    Jul 2014
    France, Brittany !
    Yes, I certainly could, but I preferred something non intrusive .
    Cheers !
    Christophe
    Congratulations Christophe Mineau - your Shredder Blade Cover Socket is the Homemade Tool of the Week!
    Nice solution for saving time, and good use of 3D modeling and a spare brass fitting.
    Lathe Compressor Installation by Rustinox
    Workbench Drill Mount by orioncons36
    Drum Sander by Vyacheslav.Nevolya
    Plate Forging Fuller by Philip Davies
    Brad Nailer Jig by Didpoolhall
    Plane Setting Hammer by e_m_maker
    Box Corner Clamp by Make Things
    Belt Sander by Mr.DK DIY
    90-Degree Corner Clamp by Didpoolhall
    Small Bench Vise by liberal
    Christophe Mineau - you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    This is your 14th Homemade Tool of the Week win. Here are all of your Homemade Tool of the Week winning tools. Congrats again
  7. The Following User Says Thank You to Jon For This Useful Post:
    Home-PC (Nov 27, 2021)
    Jul 2014
    France, Brittany !
    Thanks a lot, I'm glad this contraption has found so much interrest. It turns out to be very efficient.
    Cheers !
    Christophe
  9. #7
    Oct 2012
    Quote Originally Posted by Christophe Mineau View Post
    As I was told by my father, never ask someone how much it cost unless you can not buy it. Well never ask WHY when some one creates a piece of art like that and to my guess works well. I thought it was very nice the way he created his beautiful tool to make his job easier. Thank you Chris.
    Nelson
  10. #8
    May 2015
    Tasmania, Australia
    Bony's Tools
    Christophe, and others, my sincere apologies if my first comments were taken as being whatsoever derogatory, that most certainly was not intended.
    I always try and solve a problem with a simple solution and one that is easy to implement. In this case I could see an easier, simpler and quicker solution, that's the only reason I mentioned it. I suggest the majority of followers of this site do not use CAD CAM software or have access to a 3D printer and err towards a simple approach.
    Christophe, you have produced a very creative and elegant solution which doesn't require modification to your shredder although if I may say, a somewhat complex one. Congratulations on your win.
  11. #9
    Jul 2014
    France, Brittany !
    No need to apology Bony, there's no trouble at all, your remark was absolutely relevant, but I never miss an occasion to play with my tools and to give myself some challenges.
    Here I did know this brass copler I had could fit, but it was not easy to predict the exact milling to be done with precise dimensions . Hence the 3d modelling, I could make some virtual cuts and see the intersection between the cylinder with the odd shape of the button.
    It's just fun for me, I like doing this, and I was initially thinking of doing the complementary shape of the button with my small cnc, stacking layers of plywood I would have cut following the different sections of my drawing.
    But at the end I had fun playing with my conventional mill and the rotary table.
    But for sure, do not see any logic but trying to have fun with my tooling and finding solution to unprobable challenges I set to myself.
    Cheers !
    Christophe
