Results 1 to 10 of 12
Thread: Power hacksaw - video
    Power hacksaw. By JSK-koubou. 28:48 video:
  2. The Following 14 Users Say Thank You to Jon For This Useful Post:
    bruce.desertrat (Sep 7, 2023), Corm (Sep 8, 2023), fergiomaria (Sep 10, 2023), Moby Duck (Sep 9, 2023), mr mikey (Sep 10, 2023), nova_robotics (Sep 9, 2023), PaulsGarageProjects (Sep 13, 2023), Ralphxyz (Sep 9, 2023), rlm98253 (Sep 7, 2023), Robert47 (Sep 9, 2023), Sleykin (Sep 7, 2023), trevor_60_r (Sep 10, 2023), tuchie (Sep 7, 2023), Tule (Sep 8, 2023)
    Aug 2020
    Power hack saw
    Excellent job. Best I've seen. We need more like this and less of the dumb stuff.
    It is a nice build. Not being at all critical of the design or execution of it.
    I do have to ask the question. What are the advantages of a power hacksaw over a horizontal band saw? There much be advantages. Even a portable band saw, can be very effective and accurate.
    Band saw uses every tooth on the blade and is always cutting. Chips are constantly ejected from the cut. A hacksaw very seldom uses all of the teeth. Typically 1/2 or less of the teeth are in use. When cutting wide stock, the center teeth often never have an opportunity to clear chips. By design a hacksaw is only cutting 1/2 of the time it is in use.
    I have used a power hacksaw many times over the years. I cannot think of any situation where is is superior to a band saw.
    Once more, these comments have nothing to do with the quality of this build, just questions for discussion.
  5. The Following User Says Thank You to hemmjo For This Useful Post:
    tonyfoale (Sep 9, 2023)
    Supporting Member carl blum's Avatar
    Nov 2021
    Charleston, South Carolina
    carl blum's Tools
    Hello Hemmjo:
    While I have a 6x4 band saw, here are the advantages of a power hack saw:
    The blades cost less and are easier to replace, a plus in a home shop. Since I don't have a band saw blade welder when I brake a blade I toss it.
    You can saw through a hole with out braking the blade.
    Thicker blades can be used for heavy cuts.
    There might be others too.
    Carl.
    Apr 2014
    Gadgeteer's Tools
    Nice, over-engineered build... but, if that's what floats your boat... great! I would never have a machine in my shop that distributes swarf on itself.
    Quote Originally Posted by Gadgeteer View Post
    SO... you don't have any machines in your shop? All of the machines I have swarf all over themselves. I must not be using them right.
    What is your secret? I am so curious what machines you might have that do not swarf all over themselves in operation.
    Nov 2021
    carl blum's Tools
    PS: It would be nice if the stroke was adjustable. You could slot the bar that is attached to the motor. Carl.
  10. The Following User Says Thank You to carl blum For This Useful Post:
    olderdan (Sep 11, 2023)
    Aug 2020
    I likewise would like to know. Being a machinist all my live and I never figured it out. Hmmmm ??
    Nov 2021
    carl blum's Tools
    Hi Gang:
    Really the mess from the chips isn't bad for a saw. My band saw makes a bigger mess. If you put a vacuum inlet under the sawing area it could gather most of the chips. I might mount the VFD ( variable frequency drive ) farther from the chip area and screw the heat sinks to the aluminum frame.
    It is a nice machine.
    Carl.
  13. #10
    Regarding using all of the blade length, if you make the vice long enough it is a simple matter to insert a V block to use a new part of the blade. A small tray catches most of the swarf.
