http://www.youtube.com/watch?v=mPyu7ahEWFg
Great post! Anyone wanting to replicate your build shouldn't have a problem following your video.
Thanks The Fe Factor! I've added your Cordless Driver Power Supply to our Power Supplies category, as well as to your builder page: The Fe Factor's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="/cordless-driver-power-supply"><img src="http://www.homemadetools.net/uploads/113134/cordless-driver-power-supply.png" alt="Cordless Driver Power Supply" /></a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="/cordless-driver-power-supply">Cordless Driver Power Supply</a> <span> by <a href="/builder/The+Fe+Factor">The Fe Factor</a></span> </div> <div class="tags"> tags: <a href="/tag/power-supply">power supply</a>, <a href="/tag/cordless">cordless</a> </div> </div> </div> </div>
what kind of power supply are you using.? It looks like a unit out of a large computer server. Nice job, by the way. :clapping:
It is AC/DC power supply 90V~260V AC Input, Single Output 500w 18v
I don't think this PS used in a server of any kind, most likely this one can be used as a LED driver
Hi The Fe Factor,
Very nice work! I'm sure that a lot of guys will be interested in building one of these for themselves. Your Cordless Driver Power Supply is the 'Tool of the Week'!
You'll be receiving one of our official HomemadeTools.net T-shirts:
Attachment 3094
If you've already received one of our official HomemadeTools.net T-shirts, we'd be glad to award you a $25 online gift card from GiftRocket. Your choice!
Either way, just let me have (via PM) your details (size, color choice, and mailing address for the shirt or email address for the gift card) and we'll get things processed directly.
Congrats!
Ken
Hi,
Great post Mr Fe Factor !
It's pretty much the same solution as the one that I already presented here, also with a LED power supply (12V mine), but your build is much more well finished, that's really great !
I completely share your opinion, I hate waiting for battery charging while I'm in the flow of doing things.
I find great your idea of assembling the full thing in a tool box, with the benefit of tidying up your cable and possibly other bits.
Great idea, I will try to find one like that also !
Great emulation on HMT, each one improving the solutions of the other, that's really what I like !
Cheers,
Christophe
Thank you Ken. I'll send a PM in a little bit.
Thank you Christophe!
If I to change anything about this set up it is the size of the tool box.
The one I got is 6.5" x 7" x 15" and it is a little crowded with the 18' long power cord coiled up inside of it and possibly splice the power cord with a power connector right at the battery, so if I need to power up a 12V tool I could simply swap a battery with a step down housed inside of the battery/adapter case
The hardest part of the whole project was the search for the 18V power supply which can produce 20A +
Awesome job. Thanks for sharing such an informative video.
Al
This thread has been moved to the Must Read subforum. Congrats (and thanks) to The FE Factor for making such a valuable contribution!
I think I get it. zinc casing.. HCL.. = zinc chloride (?) and toilet bowl cleaner or liquid plumber.. same.. add more zinc.. and some water to the acid.. so far so good.. Thank you.. good stuff..
Human ingenuity never ceases to amaze me. This build is out of the box innovative. I doubt I would go thru all that if my drill driver ran out of power. I would grab a corded drill. But, that takes nothing away from this really cool tool. You could run the Dewalt radio on it in the interim. Leave it permanently set up to power cordless bench mounted equipment . Have a variety of battery dead tools set up to run off it. My cordless end grinder, router, cut off saw set in a mini table, etc.
Hi, Sorry to sound negative but surely the whole idea is for the drill to be cordless. If you are in a position to have access to mains power
then why not use a conventional mains powered drill
I have to agree. If you need to string AC extension cords to bring mains power to the location of the power supply, why not just use a mains powered drill (which is likely to be more powerful than a cordless drill)?
If one doesn't possess a mains drill, then what he's done makes better sense assuming you have an extra adequate power supply lying around or can obtain one for less than the cost of a corded drill.
When I did my drill conversion...
http://www.homemadetools.net/forum/c...ill-cord-34044
I realized that I didn't mind a drill with a cord if the cord was short and I didn't have to string extension cords to the work site. Powering the drill with an external SLA (Sealed Lead Acid) battery) turned out to be a very nice compromise that maintains the independence of battery power.
Thankfully, the advent of lithium battery technology with its long charge retention and fast recharge has put an end to many of the problems associated with NiCad batteries. I now have two Milwaukee drills that use this technology and only use the SLA setup rarely.
Well...from my own personal experience as an electrical contractor... when I am working from a lift or a ladder, drilling holes, driving fasteners, cutting conduit...I certainly don't want to deal with a corded tool. But throughout any given day on a job site, I often move to an area where I then need to be running tools almost continuously, as I install equipment, enclosures, build out equipment rooms, etc... Cycling through pricey LiOn battery packs, (that DO have limited recharge lifespans) when I could now simply, just switch their power source, is a huge plus to me. I would need to bring along the charger and extra batteries anyways. I also don't have to carry around, or go get, the corded versions as well.
Most new construction job sites I work on progress through various stages of mains power availability...almost none, temporary, (where every other trade is competing for the limited amount of extension cord chaos...and god only knows what you battery charger might be sharing a branch circuit with...), you get the idea.
Finally, I have at least 3 full sets/kits of cordless tools that were NiCad powered, and they are all great tools, but I am not buying new batteries for them. If I can use them in my home shop or garage with a set up like this...why not?
I am already planning this build for my Rigid X5 set...
My grand plan is to pick up another one of their rugged wheeled tool boxes, and mod it with:
1) AC to DC power conversion.
2) Dual battery charger.
3) Duplex GFCI receptacle.
4) Dual USB charge ports.
5) Volt/Amp display.
And my sincere thanks an hats off to the builder for a great build, and a superb video documenting it!
