Results 1 to 10 of 12
Thread: Precision Vise. Milling Vise. DIY 100% Homemade!
    Supporting Member machining 4 all's Avatar
    May 2020
    machining 4 all's Tools
    This is my version for precision vise or milling vise. I made some simplifications in the project, to facilitate the manufacture. I created an alternative model for the fixation nut and changed the fixed jaw and the movable jaw. This project is a good exercise to train manufacturing skills and patience.
  2. The Following 6 Users Say Thank You to machining 4 all For This Useful Post:
    Canyonman44 (Aug 10, 2020), DIYSwede (Aug 10, 2020), Jon (Aug 10, 2020), mwmkravchenko (Aug 16, 2020), Rangi (Aug 10, 2020), Saltfever (Aug 14, 2020)
    May 2020
    Below is a brief description of the tools and materials needed for its execution:
    - Drill 5.0 mm
    - Drill 6.0 mm
    - Drill 7.0 mm
    - Drill 8.0 mm
    - Drill 10.0 mm
    - Drill 14.0 mm
    - End mill 10.0 mm
    - Countersink diameter 19.0 mm
    - Male M6
    - Male M8
    - Plate 32.0 mm x 102.0 mm x 182.0 mm
    - Plate 32.0 mm x 62.0 mm x 102.0 mm
    - Plate 32.0 mm x 32.0 mm x 102.0 mm
    - Plate 18.0 mm x 27.0 mm x 37.0 mm
    - Round bar diameter 21.0 mm x 9.0 mm
    - Allen screw M6 x 30.0 mm
    - Allen screw M8 x 50.0 mm
    Approximate cost:
    - Plates and round bar (scrap): U$8.00
    - Screws: U$0.50
    - Labor: it's part of the fun!
    Approximate manufacturing time:
    - 3 days (with several interruptions)
    Full project available below!
    Attached Files Attached Files
  4. The Following User Says Thank You to machining 4 all For This Useful Post:
    May 2020
    More details of the project...
    Precision Vise. Milling Vise. DIY 100% Homemade!-vise-01.jpg Precision Vise. Milling Vise. DIY 100% Homemade!-vise-02.jpg Precision Vise. Milling Vise. DIY 100% Homemade!-vise-03.jpg Precision Vise. Milling Vise. DIY 100% Homemade!-vise-04.jpg Precision Vise. Milling Vise. DIY 100% Homemade!-vise-05.jpg Precision Vise. Milling Vise. DIY 100% Homemade!-vise-06.jpg Precision Vise. Milling Vise. DIY 100% Homemade!-vise-07.jpg
    Stockholm, Sweden...
    DIYSwede's Tools
    Thanks M4A for sharing an eminent build with video, pics and drawings!
    Still only monday - but perhaps TOTW?
    Clever solution to keep the fixation nut from twisting when tightening.
    What plate material did you use?
    -Not intending to be impertinent, but I wonder if you find the two M6 x30 allen bolts
    (in both shear and tension) being sufficient for holding the fixed jaw,
    or if it perhaps tends to lift upwards-backwards a tiny bit when clamping down hard?
    Some solutions use a perpendicular rear key in milled slots in the base & fixed jaw,
    thus the jaw stays put and the bolts (now just taking tension) only needs to hold the jaw down.
    ATB and TIA
    Johan
  7. The Following User Says Thank You to DIYSwede For This Useful Post:
    machining 4 all (Aug 10, 2020)
    May 2020
    Thanks DIYSwede for the comments! Answering your questions:
    - Material of the plate: by machining, probably SAE-1045 (I can't say for sure, I bought it in scrap. To have a notion, you would have to perform at least one chemical analysis). It certainly wasn't ASTM-A36.
    - Allen screws: easily found in hardware stores. If you do not have this length, buy longer and cut to adapt.
    - By my calculations, M6 is enough to keep the jaw fixed in place. If you want, you can replace it with M8.
    - As the screw fixation occurs at 45 degrees, the movable jaw tends to descend, which completely locks the part.
    - I will still manufacture tempered jaws, so there are some details to complete the project.
    I hope I answered your questions, hug!
    May 2020
    TOTW? No way...
  10. The Following User Says Thank You to machining 4 all For This Useful Post:
    poppop65 (Jul 6, 2021)
  11. #7
    DIYSwede's Tools
    M4A: -Thanks for your quick replies - I'm absolutely content!
    ATB
    Johan
  12. #8
    Thanks machining 4 all! We've added your Mill Vise to our Vises category,
    as well as to your builder page: machining 4 all's Homemade Tools. Your receipt:
  13. #9
    May 2020
    Please, reconsider the score for level of detail... I tried to pass on as much information as possible: list of materials, drawings, photos, footage ...
  14. The Following User Says Thank You to machining 4 all For This Useful Post:
    Jon (Aug 17, 2020)
  15. #10
    DIYSwede's Tools
    For further info on how to make a vise like this, Ishimura's site might be worth a look:
    MAKING OF VISE
    Note: the link to the english drawing is broken, the japanese still works
    (Caution: Metric dimensions!):
    ƒoƒCƒX}–
    While I'm at it: Ishimura's entire home page might be of use again around here:
    Mini Lathe Workshop
  16. The Following User Says Thank You to DIYSwede For This Useful Post:
    machining 4 all (Aug 16, 2020)
