Results 1 to 10 of 12
Thread: Precision Vise. Milling Vise. DIY 100% Homemade!
  1. #4
    Stockholm, Sweden...
    DIYSwede's Tools
    Thanks M4A for sharing an eminent build with video, pics and drawings!
    Still only monday - but perhaps TOTW?
    Clever solution to keep the fixation nut from twisting when tightening.
    What plate material did you use?
    -Not intending to be impertinent, but I wonder if you find the two M6 x30 allen bolts
    (in both shear and tension) being sufficient for holding the fixed jaw,
    or if it perhaps tends to lift upwards-backwards a tiny bit when clamping down hard?
    Some solutions use a perpendicular rear key in milled slots in the base & fixed jaw,
    thus the jaw stays put and the bolts (now just taking tension) only needs to hold the jaw down.
    ATB and TIA
    Johan
  2. The Following User Says Thank You to DIYSwede For This Useful Post:
    machining 4 all (Aug 10, 2020)
