Results 1 to 6 of 6
Thread: Pressing gas cylinder concave bottoms - GIF
Hybrid View
  2. The Following 5 Users Say Thank You to Altair For This Useful Post:
    Inner (May 25, 2023), mwmkravchenko (May 26, 2023), nova_robotics (May 25, 2023), Ralphxyz (May 25, 2023), Rangi (May 25, 2023)
    Mar 2019
    Adelaide, Australia
    I can’t make out what the first stage is for.
    1st operation, looks as though dumping out slag; carbon layer formed getting the end up to forming heat.
    Sure, it's upended again just seconds later, but it's disposed 'overboard', versus into the machine.
    It's only a second long, but at 0.05' the glowing pile is right at open mouth of cylinder.
    Just noticed; still shot in the mail shows it almost perfectly, video has it spilling out.
  5. The Following 3 Users Say Thank You to Toolmaker51 For This Useful Post:
    desbromilow (May 27, 2023), mwmkravchenko (May 26, 2023), WorkerB (May 26, 2023)
    Mar 2019
    Adelaide, Australia
    I think you are correct. Thanks for your insight
  7. The Following User Says Thank You to WorkerB For This Useful Post:
    Toolmaker51 (May 26, 2023)
    hemmjo's Tools
    Love to see the whole process. Does that start as pipe and they form the end closed? Or start of flat and pressed into cylinder shape?
    Found this.
    Found this.
    For those interested here is the complete start to finish video of an oxygen cylinder being made. In this video however these are made of aluminum ,different factories have a slightly different process, this is just one example. Steel cylinders are heated to much higher temperatures and the starting slug may initially be nearly white-hot while being pressed into shape
  10. The Following User Says Thank You to Frank S For This Useful Post:
    nova_robotics (Jun 3, 2023)
