Thread: Propane burner build powerful burner for forge + drawings from water pipes!
    Supporting Member manshands's Avatar
    Jun 2020
    manshands's Tools
    I made two propane injection burners according to the USSR secret books (drawings). Drawings and calculations are attached. You can calculate a garelka of any size and power.
  2. The Following 7 Users Say Thank You to manshands For This Useful Post:
    Altair (Jun 19, 2020), Andre Imar (Jun 30, 2020), Inner (Jun 28, 2020), Jon (Jun 25, 2020), Little Rabbit (Jul 19, 2020), mwmkravchenko (Jun 20, 2020), will52100 (Jun 19, 2020)
    Thanks manshands! We've added your Propane Forge Burner to our Forging and Casting category,
    as well as to your builder page: manshands's Homemade Tools. Your receipt:
  4. The Following User Says Thank You to Altair For This Useful Post:
    Coenobita (Jun 28, 2020)
    Aug 2012
    Australia
    desbromilow's Tools
    interesting use of the nuts for centering the drills - I thought I had it rough starting out working on top of a wheelie bin.
    Apr 2017
    I really enjoyed your thrifty approach to making the burner, especially how you used the knot in the wood to help form the cone. Your set up is very basic but you made a great burner.
    Normally the mixing tube's diameter expands as the gas/air mixes and exits a larger bell. I have never seen a return on the bell creating a chamber. This chamber must choke the gas and air to thoroughly mix them. I'm inspired to build one to try out and compare with my existing burners!
    Jun 2020
    manshands's Tools
    Quote Originally Posted by desbromilow View Post
    Yes, to better center the drilling axis, I first used a long nut and a drill that fits exactly in the nut hole. Then, after marking the center, I removed the nut and drilled the drill diameter I needed. It turns out as accurately as possible without using a lathe.
    Jun 2020
    manshands's Tools
    Quote Originally Posted by Coenobita View Post
    Thank you very much that you like my methods of making proets))
    A little later, if you need me, I can put a link under the video in the description for a reference book on similar burners with examples of drawings and their calculations of similar burners for blacksmith furnaces and smelters. A 1981 book by a publisher, very rare.
    The burner with such a constriction after the mixer has features, when the blowing air is completely open, the flame breaks away from the burner and because of this the burner remains cold. But the burner can only be used for furnaces, then it will work correctly.
    I always use this gas burner in my blacksmith furnace, it is very economical and easy to manufacture.
    Download plans for forging and casting tools.
