Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 31
Thread: Pulley/Fan Belt Welding Jig
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Fan Belt Welding Jig Holder. This is a jig that holds the belt material so both ends are centered on each other,
    then the belt ends are moved apart and heated with a soldering gun special tip,and the jig then closes the two half's together and thus forms the weld.
    Pulley/Fan Belt Welding Jig-001.jpgPulley/Fan Belt Welding Jig-003.jpgPulley/Fan Belt Welding Jig-004.jpgPulley/Fan Belt Welding Jig-005.jpg
  2. The Following 28 Users Say Thank You to Captainleeward For This Useful Post:
    Altair (Jan 18, 2015), baja (Apr 6, 2019), Big-Pete (Mar 18, 2021), billster (Oct 12, 2018), Canobi (Mar 18, 2021), Christophe Mineau (Jan 19, 2015), darkoford (Oct 11, 2018), EnginePaul (Oct 11, 2018), greyhoundollie (Oct 14, 2018), high-side (Jan 16, 2019), IAMSatisfied (Mar 23, 2018), j.bickley (Oct 12, 2017), kbalch (Jan 15, 2015), Metallurg33 (Aug 1, 2022), mwmkravchenko (Oct 12, 2018), ncollar (May 21, 2016), NickP (Oct 12, 2017), nova_robotics (Mar 17, 2021), olderdan (Oct 16, 2017), Paul Jones (Jan 15, 2015), quickcut (Aug 4, 2022), Ralphxyz (Mar 17, 2021), rlm98253 (Mar 22, 2018), Scotsman Hosie (Apr 6, 2019), thevillageinn (Oct 22, 2017), Tuomas (Mar 23, 2018), VegeKev (Mar 22, 2018), winmac (Dec 28, 2022)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Captainleeward! I've added your Fan Belt Welding Jig to our Welding category, as well as to your builder page: Captainleeward's Homemade Tools. Your receipt:
  4. The Following 2 Users Say Thank You to kbalch For This Useful Post:
    greyhoundollie (Oct 14, 2018), Ralphxyz (Feb 24, 2023)
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Captain,
    How fast do you have to work between withdrawing the soldering gun tip and closing the gap to form the weld? Also, is there any surface trimming needed for the welded joint after it hardens? This looks like an interesting jig for making my welded urethane belts for my small Unimat lathe and milling head setup.
    Thanks for showing this, Paul
  6. The Following User Says Thank You to Paul Jones For This Useful Post:
    Supporting Member Ed ke6bnl's Avatar
    Mar 2012
    So. California high desert
    Ed ke6bnl's Tools
    what is that belt material and where do you get it
    Jul 2014
    Hi Paul, It is important to move the hot ends back together as quick as possible, With this machine the ends are mated perfect.
    Hello ED, urethane belts, they come any length you need and size on e-bay just type in urethane belts.
    Thanks to all for your interest....:O)
  9. The Following 4 Users Say Thank You to Captainleeward For This Useful Post:
    EnginePaul (Oct 11, 2018), Paul Jones (Jan 19, 2015), Scotsman Hosie (Apr 6, 2019), Tuomas (Mar 23, 2018)
  10. #6
    I have to admit, it's the first time I've seen a homemade tool for this, and I'm happy to learn something new.
  11. #7
    Jul 2014
    DIYer your to humble.....
  12. #8
    Altair's Avatar
    Like DIYer, this is the first time I've seen such a jig. Reminds me of a bandsaw brazing jig. Thanks for sharing such an interesting jig, Cap'n.
    Al
  13. #9
    Jul 2014
    You be welcome matey....:O)
  14. #10
    Supporting Member Cascao's Avatar
    Brasil
    Cascao's Tools
    Never had luck trying to weld green PU belts....
  15. The Following User Says Thank You to Cascao For This Useful Post:
    Captainleeward (Oct 16, 2017)
