Results 1 to 5 of 5
Thread: Push-to-connect fitting removal tool - GIF
  1. #5
    Perth Ontario Canada
    For the type you are mentioning, I first saw them in China about 12 years ago. I agree with the caveats about how they can last. As long as they are not in a stressed position. But to be fair, a stressed copper soldered connection will fail. And so will many other types of connections like PEX connections. The conditions on a rig are pretty tough when you think about it. So if these can last on a rig I'd be pretty confident in them.
    As for reusing, the only ones that I reuse are the pipe end caps to do pressure tests. Water connections are for life. Going to save a few dollars on this is pure idiocy.
  2. The Following User Says Thank You to mwmkravchenko For This Useful Post:
    Frank S (Mar 22, 2022)
