Thread: QCTP height setup
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    QCTP height setup
    Hi,
    I frequently use my QCTP for holding my Dremel, for grinding or sanding on the lathe.
    Then, I need to be able to setup the height along the vertical axis with a wider range than what simply permits the QCTP.
    I have imagined this simple setup that allows for setting up the tool both lower and higher than what is possible with the original system.
    I replaced the set screw by a long screw, and I inserted this angled piece of metal sheet under the handle.
    The knurled knob stops against this inserted stop, and the vertical setting up range is widely enhanced.
    Of course, when I come to be limited, I shift to my milling square, but this takes more time to install.
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 7 Users Say Thank You to Christophe Mineau For This Useful Post:
    desbromilow (Jan 5, 2023), HUMARIA (Jul 21, 2019), Jon (Nov 17, 2015), kbalch (Nov 17, 2015), Paul Jones (Nov 17, 2015), PJs (Nov 17, 2015), Toolmaker51 (Sep 11, 2016)
