HomemadeTools.net Members
Results 1 to 5 of 5
Thread: Quality Modifactions on a Cheap Bead Roller
    Supporting Member barts metalwork's Avatar
    Dec 2019
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    barts metalwork's Tools
    I bought a cheap (HBM) Bead Roller a month ago. After some testing it was time to make some modifications. The side movement is terrible and needs to be fixed. But if I start this project I might as well do some other modifications to make it more usable:
    Adjustment hand crank
    Wide throat
    Drive hand wheel
    Stand
    Pointer
    Depth stop
    Sliding adjustment on bottom shaft
    Working table
    Dies storage
    I want to use it first without a motor, but I will add one in the future.
    The making of video is on my YouTube Channel Barts Metalwork:
    45 Best Harbor Freight Tool Modifications
  2. The Following 7 Users Say Thank You to barts metalwork For This Useful Post:
    BrianW (05-20-2020), clydeman (05-20-2020), Jon (05-20-2020), Lumalo (05-21-2020), mwmkravchenko (05-20-2020), Rangi (05-21-2020), Slim-123 (05-25-2020)
    Supporting Member mr herb's Avatar
    Nov 2019
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    mr herb's Tools
    500+ Homemade Tool Plans
    THE BEST video that I have seen,in regards to utility of design, and quality of workmanship. Worthy of some kind of award.
    What is the make of your milling machine?
    Forge Build Guide
    Dec 2019
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mr herb View Post
    Thank you. The Milling Machine is a Schaublin 13
    Aug 2016
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    wizard69's Tools
    Bart;
    This has to be one of the best bead roller upgrades I've seen. Seriously you have done a massive overhaul and made many significant upgrades. Frankly it is almost as if you started from zero.
    I'm sitting here trying to think about what else you could do beyond a motor drive. The one thing that I've always wondered about is placing a crank above the rollers, slightly to the right. This would require a right angle drive of some sort but the thought was that it would be handy for precision work or even make one man operation easier for odd shaped items. By the way not a big fan of motor drives here due to the finger pinching potential. About the only other thing I can think of is a scale for the fence, that is easy to do. Maybe something else will come up.
    In any event a fantastic post about making something so so awesome.
    Dec 2019
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by wizard69 View Post
    Bart;
    Thanks! And a fence scale is nice idea. And the crank might also work for small work. But I think I will add a motor because holding the work with two hands also improves a lot on precision work.
    Post your reply!
    eBooks for Supporters
