Hi Marv
While I like your line of thinking, I think you have taken a little bit of "poetic license" with the larger vee of the involute shape. What you really gain with this shape is a "lower" or shallower vee block (which of course may be an advantage). Given a true vee block with the same width vee as the top of the involute vee, the tangent of the true vee block would provide a more secure holding position and power than the involute vee. The curved sides of the involute vee will not be a true tangent as in the true vee block. Effectively you have two "circles" pressing against each other.
If you were to reduce the involute vee to the same width as the smaller vee shown in your images, I think the holding power of the involute vee would be of concern. In any given vee width, most nominal diameters would sit much deeper (more secure) in a true vee block than an involute vee.
Kind regards
Peter
